- Dec 27, 2008
I've been active on the AMD side for several years but I wish some input from my Intel brethren for an Intel-based system build. My daughter who lives out of state wants to put a system together herself. I will be helping her at times I'm sure via email, phone or Skype but I think she has enough tech savvy to so this. One important fact you need to know is that she will not be overclocking this system. She doesn't want the loud fan noise that typically goes along with heavy overclocking. That's why I'm leaning to the Intel side this time. It's got to perform well out of the box. Budget is approximately $1000. She already has the GPU, a GTX 580 3 gb. She will use this system for gaming and occasional Photoshop projects. So she will need a CPU that will not limit the GPU and plenty of RAM as well as plenty of quick, fixed storage. I would appreciate your input on these preliminary choices:
Core i5-3570k ($220) http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504 (chose the “k” model in case she changers her mind about overclocking. Ony $20 more).
ASRock Z77 Extreme 6 ($155) http://www.newegg.com/Product/Product.aspx?Item=N82E16813157295
Crucial Ballistix DDR3 8gbx2 CL 9 ($139.0) http://www.newegg.com/Product/Product.aspx?Item=N82E16820148545
Corsair 650-TX PSU ($90) http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
Crucial 240gb SSD ($149) http://www.newegg.com/Product/Product.aspx?Item=N82E16820148694
Segate Barracuda ST2000DM001 2 gb 7200 rpm hard drive (http://www.newegg.com/Product/Produ...ark=&IsFeedbackTab=true&Page=1#scrollFullInfo
Edit: This is the case I think she might choose: ($170) http://www.nzxt.com/product/detail/111-switch-810-case.html
Cost so far is $985 but there may be other incidentals such as OS and DVD burner.
