Trying to figure out the cheapest way to do this, I have about $40 or so for budget atm. I have 3 x 2GB DDR3 1600MHz and I wanted to try and upgrade,
ideally by throwing in a 4th stick of 4GB of the same kind and I needed some help.
I am currently running 3 x 2GB DDR3 1600MHz sticks, here is specs:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231225
I am running them in this mobo:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813141009
One thing I was confused on though was that CPU-Z shows my ram running at 800MHz under the memory tab, but when I look at my memory
slots in the SPD tab, it tells me the max bandwidth per stick is 667MHz? Is something wrong here?:
I am trying to decide if I should upgrade with one more 2GB of the same,
or just grab 2x 4GB of a similar kind like these:
http://www.newegg.com/Product/Produ...m1132X509988X9ee82b1e15601651f2c737c7faa9a4b5
http://www.newegg.com/Product/Produ...m1132X509988Xc0ad73da519e31264a81178e4839791a
But I was also thinking I could pick up a single 4GB stick of the same kind to fill my 4th ram slot, would this be viable?
Would it cause a problem to run that stick with the other 3 I already have? Such as this stick:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231313
My third option is just to grab a single 2GB stick to fill my 4th slot, which would leave me with 8GB DDR3 total, but I am unsure if that minor of an upgrade
would be sufficient enough to last a while, so I would really only want to choose this option if anyone here thinks that's the best idea.
I can post any other specs/links to my parts if that info is needed.
Thanks for any help!
