- Jan 24, 2002
Need advise on water-cooling 2U Server with 4 (inline) processors - Dell PowerEdge R810 (see pic below - I needed to quiet the massively noisy server fans - this was my attempt - did no work at all - plan B - water cooling).
The goal is to achieve adequate cooling with ambient temp max 40C. Overclocking etc. are not applicable here.
I have 2 servers to water-cool and budget is tight so I am thinking of getting some cheap water blocks from Amazon and eBay (2 of each):
http://www.amazon.com/LENX-Aluminum...2079199&sr=1-17&keywords=water+block+aluminum
http://www.ebay.com/itm/For-CPU-GPU...773249?hash=item1e94481e81:g:tbYAAOSwcu5UNOgF
I need the fittings to come out of the side because I want to use the space above the water blocks to put some additional hard drives.
For a radiator I am thinking of getting is Koolance 9-Fan (120mm) HX-1080:
http://koolance.com/radiator-9-fan-120mm-18-fpi-aluminum
The layout will be like this:
--- pump one --- server one (4 processors inline) --- pump two --- server two (4 processors inline) --- radiator --- reservoir --- (loop to the beginning)
The Processors are four Intel X7560 - 130W max heat each = 520W Total theoretical. While I am sure that even these cheap water blocks will transfer the heat to the water, I am concerned that having 4 of them inline might decrease the flow too much. What do you think?
1 *** What pumps would you recommend for this setup?
2 *** How about reservoir?
3 *** How about quiet 120mm fans?
Remember, budget is tight.
4 *** I also need advice on a reliable quick disconnect valves so that I can disconnect a systems from the loop if I need to work on it.
I used to have a water cooled personal computer a decade ago. I remember that silicone based tubes were recommended and I used clamps like these:
http://www.homedepot.com/p/Everbilt-1-2-1-1-4-in-Hose-Repair-Clamp-6712595/202309385
to clamp the hose.
5 *** What brand silicone tube do you recommend?
6 *** Anything else?
And the pic:
Thank You so much in advance !!!
to clamp the hose.
And the pic:
