- Mar 18, 2002
- texas
Hi gents, ive been lurking for a while, and I mostly read but this time I need some help. Nothing too serious just need some advice with ducting.
Before I get into it this a bit of history.
My pc was originally a Northwood 2.8c however I got a good deal on a Prescott 3.2E so I took it. I must admit that I was a bit ignorant of the Prescott line about 3 weeks ago when I got my new CPU, so when MBM told me the temp was 62C I went nuts. I thought I seriously screwed something up in the install. Checked and rechecked everything was fine. As I was seriously agitated with heat I did what any sane computer enthusiast would do and I got out the AS5, put that in, but it barely dropped the temps. I thought i was doing it incorrectly so I wasted about 5 grains of rice worth of AS5 before I decided to read up on presscots.
Ofcourse my dumb a$$ finally reads here that prescotts run a lot hotter than your run of the mill Northwood so i let my last and most meticulously installed load of AS5 sit. Feel free to barrage me with insults, I guess I deserve it for my ignorance. Anways, im one of the tinkering guys so I decided to see what else I could do because under load my cpu would hit over 70C and I would pull hair out over that. So i decided to go ahead and go the ducting route per intels ducting method and Bill Leggets article.
I cut 2 holes in the side of my box with my dremel. Everything went pretty smooth. First time I have ever done this and the side of my box is see through plexiglass with an indention so it was kind of a pain to get some of the edges straight. Plus, this stuff will melt so I had to keep water running over it to keep it cool. The first hole for the 120mm fan was for my CPU and that was the 2nd one I drilled so it came out looking ok. The second hole is a smaller 80mm i believe which I decided to use for my GPU and since it was my first cut the hole isnt exactly too appealing. Luckily after I put the fan cover over the hole it covered of the gory pre-school hacking that I did to my case. All in all it looks quite smashing at the moment with everything in place.
WHOA! The temps dropped a whopping 14C from that alone and I idle at about 48C sometimes 49C. My ambient is 32C and my mobo is 35C so it's not too bad to have a Prescott 3.2E idling at 48C, atleast that's what I think mind you that is coming from an ignorant prescott guy that wasted 5 grains of AS5. Good news is, I have never seen the temps rise above 62C since and I'm a hardcore gamer mind you. This is all without the ducting installed yet, just two fans blowing in.
Regardless and to the main point, I want the temp even lower than this so that I can ofcourse OC this mofo . So the question remains, what is a good duct that will fit over my 120mm fan?!? I found this aluminum ducting at home depot that would be perfect for my 80mm fan but the 120 is just too big. Not to mention I would need it to scale down a little bit so it would cover the HSF on the CPU. The aluminum ducting is about $7 and I can buy that but I cant use it for both and it seems kind of expensive. If i was to find say 120mm ducting I could atleast bend the crap out of it so it would fit over the 80mm fan.
Anyways, all you guruji's out there that live an breath this stuff feel free to help out a novice pup who would like to get an ideal duct that can be retrofitted to work for both fans rather than buy one for each. I know I can upgradge the HSF but I'm putting off upgrading the HSF till I know how low the temps will go with this setup.
Thanks for your reading, your time, and attention, have a wonderful day
-Injun
-Injun
