- Apr 5, 2012
I just recently got into overclocking. Pushed my i7 960 to 4.05ghz and put in an H60 to compensate for the temp (runs high 70s to low 80s under stress, which is fine).
I put in a second Radeon HD 5770 (crossfire), and now I cannot keep the temperature under control, even when both are not oc'd... I have 4x 120mm fans (doing push/pull). The radiator for the H60 is sandwiched between 2x 80mm (i think they are 80s) fans, pointing the same direction (into the case).
I have no more slots for fans on my rig, and am trying to avoid gpu water blocks due to my inexperience, but I will go there if I need to.
Is there a case I can buy with extreme air cooling? Self contained water system I don't need to mount onto each gpu? Are gpu water blocks easier than they seem?
Thanks tons. I cannot wait to fix this so I can get back to playing BF3 at max settings with 50-70 fps...
Edit: I read somewhere that an inadequate power supply could cause gpu overheating. AMD recommends 600w for 2x 5770 crossfire, and i'm running a 750w. Just wanted to clarify that isn't an issue here.
