as far as i know you cant,
i think the most you can really compress files depending on what they are is like 20% so a 200mb file would get down to about 160mb.
Only with compressing simple text file you can achieve such results.
But if it somehow related to email quota limit for attached files - you can split your archive my 25mb files. And send 10 emails.
Freearc is way better than 7zip by far. He just updated the alpha today http://freearc.org/Download-Alpha.aspx
Audio and video files are not compressable. Many large pdf's aren't either.
Tom's hardware? really? Please... I have tested it personally against 7zip and winrar with hundreds of gigs of data and I can say for a fact it is better. Plus 0.666 is the old version it's at 0.67alpha. 7zip would be my second choice as it comes very close but freearc does give slightly better compression and has many many more features than does 7zip. 7zip's gui is like 1998 compared with freearc's. Freearc uses the gtk runtime & themes which there are a lot of. I believe 7zip needs a 3rd part ap to skin it, if at all. I keep Peazip portable on my slave and it is always updated but freearc gets the nod in windows, not 7zip. Btw, my default in freearc is best assymetric which is the same as 7zip's default compression . I rather see no need to do ultra compression when many times best is the same size and ultra just takes longer. Also that chart is a joke. Winrar is right up there with winzip compared to arc or 7zip.
That's cool. Really 7zip's actual compression is on par with freearc's to where you would hardly notice a difference unless you were looking for one. It's a snap to use the latest 7z.dll and the 7zg.exe in freearc and make 7zip it's default compressor. Piece of cake. Arc is just plain better though. Plus freearc's gui does things 7zip can only dream of. I use arc for my personal files and 7zip for public ones. The only thing it lacks which is the only thing I miss about winrar was the ability to drag and drop to explorer. nbd
Maybe you can try write to 7-Zip creators to do this:
The two relevant things when it comes to super-fast computing which are GUI-related are the ability to
1. Right click on a file and have a little icon which guides your eye to it and have the one and only zip option which is Add to [name of file].zip like so:
2. Right click on a compressed file and have a little icon guide your eye to it and have the one and only zip option which is Extract to folder [name of file] like so:
I asked them to do that many years ago but they did not think it was important back then. WinZip cannot compete with the others but I zip/unzip files faster because of that icon and ability to remove all other right click shell options except for the only ones that matter: Add to [name].zip and Extract to [name].
Heh, I have been trying to figure out how to customize the right click menu by inserting my own icons just like the native WinZip icon next to right click menu options. I've been trying to do this using numerous shell editing programs since 1990s without success.
Make a 7-Zip right click menu option that does what those pictures show WinZip can do and I will switch to 7-Zip immediately, not to mention a big thanks for something I've been waiting to figure how to do for like 20 years!
