johnson5067
- Nov 4, 2014
Hello everyone. This is my first build and I'm at a point where I've researched as much as I can but I still cannot determine what the best platform is for my needs. The computer will primarily be used for my wife's wedding photography business. She usually edits batches of ~1000 images in Lightroom, but also uses Photoshop, Illustrator, and inDesign a little bit on the side. I will be using this computer to play Minecraft, so nothing super GPU intensive in terms of gaming. From what I can tell the priority for us is going to be CPU and RAM. Budget for this build is ~$3000 and I don't want to go any bigger than a microATX motherboard. (I'm pretty set on the Corsair air 240 because I really like the design and we are limited with respect to space for the computer.)
After some initial research, I landed on the i7-4790k and put together a potential parts list around the Z97 platform. I asked for some feedback on Tom's Hardware, but posting there hasn't been super helpful to me, hence why I'm here! I had one guy say the 4790k would be fine but another saying I absolutely had to go with a Xeon in order to build a proper workstation. I did some more research on Xeons and workstations. I wouldn't say my wife's business requires "mission critical" hardware but I do understand the argument that workstation components are built to be more reliable and run 24/7 (ECC RAM in particular). I also understand that Xeons have an added benefit that they do not contain integrated graphics, since I'm already planning on having a dedicated (mid-level) GPU.
I also did some more research and saw the i7-5820k that was recently released for the X99 platform. This being the newest chipset it has all the new optimizations for improving performance and efficiency... plus you get to utilize the new DDR4.
Anyway, I'm pretty much stuck now and don't have any clue which way to go on this. I'm sure all three would suit our needs but I just want to be absolutely sure before I pull the trigger on either the 4790k, 5820k, or a Xeon build. Right now I have two PCPartPicker lists built, one for Z97 and one for X99. Can someone please help me just pick which processor/chipset I should go with? Then I can start finalizing the list and figuring out all the other questions I have like what RAM should I get, should I set up any storage in RAID, what kind of GPU/display do I want, etc...
Btw, I'm an engineer and I'm definitely up for learning the art of overclocking and getting stable, high-performance out of either the 4790k or 5820k, so if I go with one of those I think I will at least attempt some moderate overclocking. However I also don't mind if the Xeon is the best route due to reliability, or if I should go this route to be safe and not put my wife's business pc at risk because of overclocking or "consumer-grade" hardware.
Thanks for reading, I appreciate the help!
