- Aug 15, 2002
- Toronto, Canada
ACTF_Heat said:Well,I have 2 512mb sticks of Corsair XMS ram....will the a7n8x-x work well with that RAM,or should I get the deluxe version and return the a7n8x-x?
Edit*-its pc3200 ram
It should work the same on either Mobo. See the specifications page on the link I provided you in my earlier message. it has a listing of known compatible ram. (although others unlisted will probably work) Corsair PC3200 is in the list.
The only reasons you should be considering the Deluxe version for:
1: If you think you may go SATA in the future.
2: You want the Soundstorm Audio. (you can always disable both if you have no need for either right now but might in the future...and if a few extra $$$ wont kill you)
Al
