Mother Board (EVGA X58 3XSLI CLASSIFIED E759-A1 )
Drivers ( STOCK, NEVER UPDATED )
Bios ( STOCK, NEVER UPDATED )
CPU ( I7-940 ) (with 920's please also add the stepping CO or DO)
CPU Cooler ( COOLERMASTER V8 )
Memory ( Corsair Dominator 12GB 1600 DDR3 )
PSU ( IN WIN COMMANDER 1200W )
GPU ( GTX285 SSC/ REPLACING WITH GTX480 SC SOON )
Drivers ( 197.13 )
Operating System ( Windows 7 64 Ultimate )
Frequency Control
CPU Clock Ratio ( 22X )
CPU Host Frequency (Mhz) ( 170 )
MCH Strap ( Auto )
CPU Uncore Frequency (Mhz) ( Auto )
CPU Clock Skew ( 0 ps ) Can't find this in Bios
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 100 ) If using SSDs, Check with your SSD manufacturer before raising above 100.
Memory Feature
Memory Speed ( Standard )
Memory Control Setting ( Enabled )
Memory Frequency ( 1333Mhz 2:10 )
Channel Interleave Setting ( 6 Way )
Rank Interleave Setting ( 4 Way )
Memory Low Gap ( auto )
tCL Setting ( 9 )
tRCD Setting ( 9 )
tRP Setting ( 9 )
tRAS Setting ( 24 )
tRFC Setting ( 88 )
Command Rate ( 2t )
Voltage Control
EVGA VDroop Control ( With VDroop )
CPU VCore ( 1.36250 )
CPU VTT Voltage ( +300 )
CPU PLL VCore ( auto )
**IOH PLL VCore ( auto )
QPI PILL VCORE (auto)
DIMM Voltage ( 1.65 )
DIMM DQ Vref ( +0 )Don't see this in Bios
IOH VCore ( Auto )
IOH/ICH I/O Voltage ( Auto )
ICH VCORE (Auto)
**BR04 ( NF200) Voltage ( auto ) (only on E-759)
**VTT PWM Frequency ( 250 KHZ )
**CPU PWM Frequency ( 800 KHZ )
**CPU Impedance ( auto )
**QPI Signal Compensation ( auto )
ICH VCore ( Auto )
*PWM Frequency ( Not Used on Classified )
CPU Feature
Intel SpeedStep ( Disabled )
Turbo Mode Function ( Enabled )
CxE Function ( Disabled )
Execute Disable Bit ( Enabled )
Virtualization Technology ( Disabled )
Intel HT Technology ( Enabled )
Active Processor Cores ( All )
QPI Control Settings ( Enabled )
QPI Link Fast Mode ( Enabled )
QPI Frequency Selection ( auto )
OC Recovery ( Disabled ) Don't see this in bios
Turbo Performance ( Enabled )
after 3 hours using these settings, I got a bsod saying...The system encountered an uncorrectable problem
I'm guessing my voltages need some tweaking, if someone could help me out that would be great. thanks
Drivers ( 197.13 )
Frequency Control
MCH Strap ( Auto )
Memory Feature
tCL Setting ( 9 )
tRCD Setting ( 9 )
tRP Setting ( 9 )
tRAS Setting ( 24 )
tRFC Setting ( 88 )
Command Rate ( 2t )
Voltage Control
IOH VCore ( Auto )
ICH VCORE (Auto)
ICH VCore ( Auto )
CPU Feature
