- Thread Starter
- #41
If you really want to benchmark:
Best motherboard you can get, ASUS ROG boards are very popular there.
Fast RAM
Water doesn't offer huge benefits over air as both are still limited by ambient temperatures. With benching, you usually want to use dry ice or liquid nitrogen. You obviously don't want to put that kind of stress/risk on your daily rig. That's why a lot of people have a separate daily rig. Benching, you typically buy hardware, bench it, sell it, and move on to other hardware.
2011 vs 1155 also depends on whether the benchmark is multithreaded or not. If it is, 2011 is probably going to beat 1155. If it's not, you probably want to stick to 1155. Sandy vs Ivy, Ivy had a 3-5% inherent lead over Sandy, so it depends if you can get Sandy to clock that much higher than Ivy to make up the difference.
thanks Knufire!
Guess I should clarify the benching comment...not looking to get too crazy ala LN2, etc...just want to place better than some other peer builds (still trying to get up to 20 points at hwbot hehe). Would try to go nice and high for benching but bring the components down to more reasonable levels for gaming.
Thoughts on nice ram?
The benchmarks are a mixed bag threading-wise and thinking to go broad rather than focus in on one or two specific benchmarks. This is primarily a rig for gaming.
Went with the Extreme9 board as it's got plenty of PCI-E slots and will let me run the 3 cards at PCI-E 3.0 x16/x8/x8 and still have room to add another card down the road (also at x8). That's the only 1155 mobo that I could find that can do that.
From what I've read, the Ivy's aren't the best overclockers which is why I'm now re-considering the cpu and socket choices. Ivy's 1155 only atm, 2011 only Sandy atm. If Sandy...then it's down to the 3820 or 2500K/2600K and the 2xxxK cpus seem to generally overclock much better than the 3820.
The ASUS Rampage IV Extreme and Formula boards look outstanding.
So...still stuck in the 1155/2011, Ivy/Sandy, 2xxxK/3770K/3820 decision :/
