Hi all. So after a few months of asking here and there for stuff I decided to make a thread and ask for some help here and of course show you all my progress. I am starting a new build, SECOND EVER, and FIRST WATER COOL. Yup, I am just diving in. I made my first build about 4-years ago and got all my parts and ideas from people here. So THANKS FOR THAT. Anyways, I am a bit stuck and need a bit of help in the water cooling parts. What I have so far.....
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
Motherboard: Asus ROG MAXIMUS VIII HERO ALPHA ATX LGA1151 Motherboard
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2666 Memory
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive
Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
Video Card: Zotac GeForce GTX 980 Ti 6GB AMP! Omega Edition Video Card
Case: Fractal Design Define S w/Window ATX Mid Tower Case
Power Supply: Cooler Master V850 850W 80+ Gold Certified Fully-Modular ATX Power Supply
So far the total is: $1719.71
Now I have PETG tubing and a heat-gun and that is what I am going to use to bend the tubes. First time doing this and I am a bit nervous but I have seen plenty of tutorials and I think I can do it.
So I am stuck on the water loop parts. Plates, fittings, pump and whatever else I need is the part I got lost. So this is the help I need right now.
Does the 980 Ti need a back plate? What is a back plate for? So it needs 2 parts to water-cool it, the BLOCK and a back plate? I don't seem to understand this part. This is what I found and I have no clue what to get or not get.
https://www.ekwb.com/shop/water-blo...force-gtx-9x0-titan-x-series?osnovne_option=9
https://www.ekwb.com/shop/water-blocks/vga-blocks/fc-backplates/nvidia-geforce-series
I also found these links while searching but again I am a bit lost and some of this stuff might mean nothing and I am just overwhelming myself for no reason but if anyone can enlighten me that would be awesome.
http://www.xs-pc.com/waterblocks-gpu/razor-gtx-980-980-ti-backplate
http://www.evga.com/Products/Product.aspx?pn=400-CU-G991-B1
http://www.performance-pcs.com/xspc-full-cover-razor-titanx-980-980-ti-waterblock.html
This is the block I am thinking of using for the CPU unless someone has something to say about it.
https://www.ekwb.com/shop/ek-supremacy-evo-acetal-nickel
Tube is PETG as you all may have read already, I hope that works fine.
Pump/reservoirs I have no clue... I was thinking this a combo from EK? If anyone has any better idea please I am all ears (eyes).
https://www.ekwb.com/shop/reservoirs/reservoir-pump-combo
Radiators? No clue, anyone? Just linking what I find at EK if anything is better brand or preference to anyone let me know I want to learn some more
https://www.ekwb.com/shop/radiators-fans
COOLING LIQUIDS? I was thinking pastel but I read a lot it clogs the system? I mean, if you take care of it then it shouldn't right?
Last are fittings, I think. I have no clue about these so I again need help . I think pressure fittings would be best in my opinion but ill see what people have to say.
I am sorry for the long writing and bothering but I want some help and I know here is the best place for it. Please let me know aht you think and what I may be missing or anything esle.
THANKS!
THANKS!
