Hi Guys,
I messed my OS up and am now forced to reformat as I had not backed up. I can not remeber how I had bios settings set since I have been trying to get back into windows but have given up. Before I start a fresh format I want to make sure I am setting up the best way as I noticed boot times seemed slow but this may only be due to detection of the raid arrays
windows 7 64 bit
2 x Vertex 60GB SSD raid 0 on SB750 for main OS (latest firmware running GC)
2x WD640 Blacks raid 0 on SB750 (data/music/extra games)
1 x 250 esata external (backup)
1 sata dvd drive on SB750
1 ide dvd drive
x4 955
8 gb Mushkin Ascent PC12800 7,7,6,18
In the bios under integrated peripherals I had the following:
1)integrated peripherals> on chip stata controller>enabled
2)integrated peripherals> on chip ata devices> raid mode = raid (not ahci or ide)
3)integrated peripherals> E-sata/HW raid controller> enabled
4)integrated peripherals> E-sata controller mode> IDE (choice is IDE or AHCI)
5)drive booster (HW Raid) > normal mode (default setting)
5)Advanced Bios Settings> boot sequence was the vertex raid 0 array
When I set up the main Raid 0 array and Win 7 OS I installed required raid/ahci driver via a USB during install.
Should I set #2 & #4 both to AHCI or #2 AHCI for raid ) OS array and leave #4 IDE ??
Whats best method for Raid 0 ? Or should I be using the jmicron controller for the Main OS raid 0 array and leave the WD 640 array on the SB750? from what I have read the jmicron 2 blue sata ports is not seen by most as the way to go vs the black 6 SB 750 sata
Hoping I can get some quick feedback so i begin fresh format and set this up proper then overclock system before I load my games and set up my email and other crap. AND then BACKUP reg via Acronis which I should have done which would have avoided this mess
CK
windows 7 64 bit
1 ide dvd drive
x4 955
CK
