Hello there,
I have had a Strix GTX 980 for about 3-4 years now and I have recently discovered that one of the fans is not spinning - I think it stopped spinning some months ago, when my performances started being significantly lower than before (and yes, it is kind of stupid that I didn't figure out what was the problem). Since this morning, I have been trying several things, veryfying all the power cables and everything, but I'm not sure I am going to get it to work, and anyway, I think that switching from air cooling to water cooling would be a nice thing for this card model that is getting quite old now - five years since realease, if I'm not wrong.
Other thing is, my CPU is also a bit old (and was not the best at the time I bought it): it is a i5-4440. I am considering upgrading to a i7-4790k, if I can find a plan on eBay or something. But I would definitely consider water cooling my processor.
As you may understand, I do not want to buy a new grahpics card and spend a ton of money into new stuff. So, do you have any ideas, solutions for me? I don't want to spend 500$ for a watercooling system. I know there are some solutions - Corsair made some - that adapt to any GPU, but is this really a nice thing? And, what if I want to overclock both GPU and CPU, since they are all-in-one pieces? I guess I would have two loops and two rads, which seems a bit stupid.
Anyway, I'd really love to have less sound from my computer, since my GPU (well, the one fan that still spins) is making a ton of noise and I love quiet evironments.
Even if the card is getting quite old, I have seen a few waterblocks for the Strix architechture, as this one: https://www.ttpremium.com/product/pacific-v-gtx-980-v2/
(I absolutely need to use a block that is made for my precise architechture, right? I admit I may look stupid by asking this question. But I want to be sure, I can't use a block that is made for the reference design?)
I could use any help or advice, thank you in advance
P.S.: I don't give a monkey - to be polite - about aesthetics, I use a big black opaque Silencio case and never feel like I want to see what happens into it.
Also, I precise that my final goal here is to be able to freely overclock my GPU and CPU.
