this is driving me insane now been at it for hours.
i had do do a fresh install of windows 7 which all seemed to work fine all updates are installed and all mobo drivers ect are installed.
problem is i install gfx card drivers when i reboot i get the starting windows screen and then it just goes black. pc sounds normal and keyboard and mouse light up. weird thing is if i enter the bios first then discard changes and exit it starts up fine??
im trying to install amd 13.11 drivers. i had these installed before i had to re-install windows and they worked fine.
could this be a bios setting? when im in windows everything is running perfect but can only get into windows if i enter bios setting first.
