- Jun 21, 2011
I've been a lurker for a while and registered because I need some help. I am building a new system and having problems with the water cooling.
The system is made up of the following;
Logisys CS8009BK case and it's built in cooling (Same as Ikonik RA 2000 liquid)
ASUS Crossahair Extreme Motherboard
AMD 1100T Black
16gb GSkills Ripjaw DDR3 1600
A pair of ASUS HD 5670 Crossfire cards
Antec TPQ-1200 Power Supply
300gb Raptor boot drive
A pair of WD10EALX 1TB drives raid 0 for data
I have Windows 7 64 bit loaded and stable with the 1100T at stock speed.
The problem is with the cooling. On water I idle at 38C and Prime95 takes the temps to 70C within minutes. This is with the pump and fan controllers set at "Performance" which is the max setting. I know the pump is running and I've purged the air more than one but still no luck.
If I take off the water block and place the stock cooler that comes with the 1100T the system idles at 28C - 30C and Prime95 running for 2 hours averages 48C never goes above 53C.
This is my first water system and I need ideas on fixing the cooling so I can get this thing overclocked.
AMD 1100T Black
