did amd overdrive for 25 mins had also cleaned out the cooler and gpu temps went down like 3-4 degrees so now at like 43 max at 100% on all cpus
And what is cputin checking out other post on overclockers.com its supposely a bogus reading
43c sounds too low when running a full stress test. Are you sure you actually engaged the test? Seriously, you can select the AOD stress test and not actually start it. I have done exactly that, and come back a while back thinking "wow, this thing is really running cool?, and then I see that I did not actually engage the test. Are your CPU readings all pinning @ 100%?
AOD running stability test.
And lets take a newer game like diablo 3 that game like never crashes on me
try pulling out all but one stick of mem, test it till it crashes then try another ram slot then another stick of ram till you rule out all sticks of ram or find the bad one.
+1 lolYou could always try the "Inquisition Method" to locate the trouble. Here is how it works: Take a sledgehammer and whale away on a piece of hardware that you suspect might be the problem. If the piece survives the hammerblows, it was obviously "innocent". If , on the other hand, the piece of hardware under scrutiny bashes into a million pieces, it was "guilty" and needed to be replaced.
