- Jan 22, 2012
- Inside a Cooler Master 932 HAF
Working on a friends laptop an Acer wont boot up, keeps cycling "BOOTMGR MISSING" I have done the following:
I made a bootable Kaspersky USB after trying the usual insert Windows 7 CD and go to system repair. Well it seems to boot Window 7 from cd but hangs a huge white cursor for hours. I then attempted to use the bootable USB with Kaspersky on it.
Nada so I have a hornets nest to say the least what other options do I have? I checked the Bios and there is some unusual password for the hard drive that says frozen I reset the battery on the bios everything was clear then but after it starts booting nada go back into bios and yep password for hard drive is :Frozen so its safe to say there is a bad virus there ?
Any ideas?
Any ideas?
