Hello, I'm new member of Overclocking using AIO cooling
I just want to ask some information about the liquid temp of Kraken X61, For some reason my liquid temp in my loop never goes higher than 40oC even when i stress test my CPU, the temperature of the core is around 85 to 90oC but the liquid temp in the loop is just around 30 to 33oC , it's really different than my friend's, his system liquid temp can go up to 44oC while his core temp is 91oC but mine can't, I also check all of my mount and the thermal paste that i put, they are completely fine so i'm just wondering if it has any problem in my cooling system. because the liquid temp is so low so i think it's not working at 100% efficiency
My system is i7 4790K OC to 4.6GHz 1.255 vcore ( stress test CPU temp core go up to 88oC)
Does anyone using Kraken X61 and having same liquid temp as mine system, Thanks
Using Coollaboratory Liquid Ultra
Can't pass stress test at High
Using Noctua NT-H1 and replacing Fans Noctua NF-A14 industrialPPC-3000 PWM
Pass all stress test and also running AIDA64 10 hours
