- Jul 15, 2013
ok so i have a gigabyte GA-X58A-UD3R with 16gb ddr3 ram and a xeon w3690 hex core. the cpu has an unlocked multiplier which is why i bought it. cooling my cpu is this AIO http://www.coolermaster.com/cooling/cpu-liquid-cooler/masterliquid-lite-240/
alongside 3 120mm fans that produce a 3.33 mmh20 static preassure
my questions are these
#1 whats the highest safe voltage for my cpu that i can go i dont wanna over volt my cpu nor do i wanna push the voltage to high
#2 when monitoring the temps while stress testing with prime95 whats the max safe temp for this cpu? i.e. if the cpu get to this temps then its to high to be a safe temp
#3 how high can i push this cpu id love to achieve 4.5-4.9 but 4.0-4.5 is ok
#4 how many hours should i test under prime95 to ensure stable sysem also what test setting in prime95 should i use
lastly i will be adjusting the multi instead of the BLK seeing as how this cpu is unlocked, below is the link to my mobo
https://www.gigabyte.com/Motherboard/GA-X58A-UD3R-rev-20#ov
not a noob just figured id ask the pros before i overclock as its been a long while since my last overclock during the socket 775 days
