Hello dear Overclockers.
So I am in a dilemma with water-cooling. But before I start let me tell you about my rig (and my story)
So I bought a new PC in may 2014, it was suppose to be the smallest yet the most powerful mITX build I could get, so I ended up with
Case: Fractal-Design Node 304
Motherboard: Asus ROG Impact
CPU: i5 4670k (Noctua NH-D12 cooling it)
PSU: Corsair AX760 Platinum
RAM: Crucial Ballistix Elite 2x4Gb 1866Mhz
GPU: EVGA 780ti
This is a good build and everything but the Gpu is too loud and I now see that I barely have any space to build into this nor adding any other component. So now to the point ( sorry for a long intro)
I want to water-cool my system for better temps and less noise. But the case is not is barely compatible with Liquid cooling so I want to move to a slightly bigger case (any ideas? It must be as small as possible yet with lot of space for custom loop)
So I've never done a custom loop before and I have absolutely no idea in terms of brands and components needed for water-cooling, I live in Iceland so it is very hard for me to order any components and ridiculously expensive also the demand for custom loop in Iceland is not much so I would rather not end up with unusable components, so I would prefer to order everything in one order. So for starters how big radiator does it need for a GPU, I am not going to the most extreme level but I am not going to save a few bucks and not like it in the long run and have to order a new radiator or what ever component needed for the system. I would like to water-cool both the cpu and Gpu and then maybe later have the option to add in another card for SLI and being able to cool all three processors. Would it be better to have 2 separate system, one for the cpu and another one for Gpu/Gpu's.
Also because I have the mITX case now wouldn't it be better to just buy a new case and using the mITX motherboard with it for starters and if I decide to upgrade I would just buy a new motherboard for the SLI?
I hope you guys understand where I am going with this, I would appreciate if you guys could make a package of a good custom loop. If there are any questions just ask I will try answering them as soon as possible.
GPU: EVGA 780ti
