Hello overclockers! First i want to apologize for my poor english (not my first language)
I need your help with a little diy project i´ve been working on.
i have a packard bell laptop (model easynote ts44hr) and it keeps overheating. Maybe is because the thermal paste is worn off or it has some dust in the vents , but considering everything i did read on the internet about easynote laptops overheating i think is just a faulty design ( also taking apart the laptop to reaply thermal paste and cleaning is VERY difficult and i dont want to break anything)
So i need something to cool the laptop. Here is my idea:
i want to use a peltier cooler (like the ones in most usb mini fridges) (http://en.wikipedia.org/wiki/Thermoelectric_cooling) peltier devices are little plates that when applied electricity one side gets very hot and the other side gets very cool . Knowing that i want to put a heatsink on the hot side so the heat gets dissipated to the air and another heatsink on the cold side with a fan facing the air intake of the laptop so the air being sucked into the cpu is colder and thus cooling the inside of the laptop,
Now the questions: will it work? will the cold air cool more efficiently than room temperature air? Will the temperature drop be enough to justify all the work?
And regarding the peltier plate: i am going for a 30W peltier cooling plate (this in particular http://dx.com/p/tec1-12705-diy-cooling-plate-white-40-x-40mm-dc-12v-182008) cause i figured out i dont need a lot of cooling power like reaching sub zero (celsius degrees) temperatures , just below ambient.
Is this a viable choice? how big should the hot side heatsink be, and how much voltage do i need to apply to reach said below ambient temperatures?
So thats all!! i know its a long post so thank you in advance just for reading.
And if you can tell me your opinion on the project or make some adjustmen that would be very appreciated.
