- Sep 8, 2002
I'm in a time crunch as I need to rebuild a graphical production computer ASAP. I've got the hardware, I'm ready to go, but now I need to figure out if I should stick with XP Pro, or make the switch to XP Pro 64.
Hardware:
MoBo: Gigabyte GA-MA69G-S3H
RAM: 3x2GB DDR2 PC6400
CPU: AMD Athlon 64 X2 Dual-Core 6000+
I already know about the physical memory limitation of the 32-bit OSes (such as with XP Pro). My question is targeted on CPU performance.
Because XP Pro is 32-bit but my CPU can run in 32 and 64 bit mode, I'm wondering how much of an improvement I would see making the jump to XP Pro 64. For instance is a 64-bit OS on a 64-bit CPU twice as fast as a 32-bit OS running on a 64-bit CPU? Ten times as fast? An additional one-tenth as fast? An additional one-one-hundredth as fast? (these are just obscure figures I'm throwing out to let you know what I'm wondering )
I'm just looking for a quick understanding so I can figure out if I should *wait* till I get XP 64 to rebuild the system, or should I rebuild with the regular XP Pro since the difference in performance isn't *that* significant, and simply load on XP Pro 64 (clean install) when the time is convenient?
I hope my question hasn't gotten garbled in my haste. Thanks for anyone's thoughts and opinions on this.
PS. the graphical production comp that I'm working on right now is a 3400+ on XP Pro and it doesn't have the juice to keep up with the sort of work that needs to be done with it. I'm in the middle of a big project, so that's why I'm in a time crunch
PPS. The main program I'm using for this computer is Photoshop CS2, which in and of itself is also a 32-bit application. Not sure if that makes a difference for the answer I'm after.
Hardware:
