- Oct 6, 2004
- Philly
I have a Biostar TA890FXE. Yesterday I installed a water-cooling loop. I plugged in all the headers, but the power button wont work. The reset button works, but the power button doesnt. To further investigate, I plugged the reset header into the pwoer header, since I know the reset button worked fine. This did not turn on the computer. Then, I took the old power header out of the other case I just replace, and that header will reset the computer if I plug it into the reset spot, but it wont power on the computer.
What could be the issue here? Fortunately I can turn the computer on directly from the motherboard, but I'd like to be able to turn it on from the buttons on the front. Is my motherboard defective, or is there something that I might need to change? What do you guys think?
