- Apr 20, 2004
- JAX, Mississauna
Uh Oh. I cannot see how that mounting system can be working to hold the block on straight or make that flat to the cpu at all.
And thee are only two screws applying pressure when there should be four. The Pug, if you cannot get a back plate at a reasonable price you would be far better off getting a good aftermarket air cooler. There is nothing magic about have a water cooler. They are not necessarily better than an air cooler.
What country do you live in? Perhaps one of our members lives near you and can suggest some venders.
Forget the backplate, it won't work, the blocks not designed for amd, a new block is what is needed, then all will be good
Can you breach the loop on a self-contained system like that and still get it back together so that it works? I don't know. Never tried it.
So what you are saying is that even if I get the backplate that is supposed to make it compitable to the am3 socket it's stil wrong..?
You need a mounting plate like this one, made to fit the AMD socket and also compatible with your EK Supreme Ltx water block, which I don't think the one I linked is. I don't know if they even make a mounting plate for your waterblock to fit an AMD.
It's not AIO mate, just needs a new block and he should be good to go again
