These are all the parts I'll be buying in the next few weeks. I also plan on upgrading to 2 video cards at one point. I will be using this rig for heavy rendering and possible video editing.
Case:Cooler Master RC-922M-KKN1-GP HAF 922M ATX Mid Tower Case (Black)
CPU:Intel Core i7-2600K Processor with 8 MB Cache, 3.40 GHz for Socket LGA1155 - Unlocked Boxed
GPU:EVGA GeForce GTX 560 Ti Superclocked 1024MB GDDR5 PCI-Express 2.0 Graphics Card - Lifetime Warranty 01G-P3-1563-AR
PSU: Corsair CMPSU-950TX 950-Watt TX Series 80 Plus Certified Power Supply Compatible with Intel Core i7 and Core i5
Mobo:ASUS P8P67-M PRO LGA 1155 SATA 6Gbps and USB 3.0 Supported Intel P67 DDR3 2200 Micro ATX Motherboard
RAM:Corsair Vengeance 12 GB ( 3 x 4 GB ) DDR3 1600 MHz (PC3 12800) 240-Pin DDR3 Memory Kit for Intel Core i7 SDRAM CMZ12GX3M3A1600C9
HD: (2) Western Digital 1 TB Caviar Green SATA Intellipower 64 MB Cache Bulk/OEM Desktop Hard Drive WD10EARS
Heatsink: Cooler Master RR-B10-212P-G1 Hyper 212 Plus 775/1156/1366/AMD/AM2/AM3 Universal Direct Contact Heat-Pipe 120mm Fan CPU Cooler
CD/DVD Reader: Lite-On LightScribe 24X SATA DVD+/-RW Dual Layer Drive IHAS424-98 - Retail (Black)
Fan Controller:AeroCool Touch2000 Fan Controller
Extras: ASUS USB-BT211 - USB Bluetooth 2.1 Adapter - EDR (3Mbps),NZXT IU01 Internal USB Expansion (Black),SATA Data Cable (2pk.) ,Syba SY-CAB40007 Molex 4 Pin to 2x 15 Pin SATA Power Cable (5.5 Inches)
I have a few questions for you guys.
1.Am I missing anything in terms of cables or anything else?
2. Will everything be compatible? I've read stuff about all of the parts but I just want to double and triple check before I go off spending money.
3. Will all 3 RAM's fit on the Mobo with this heatsink in, I read that there is a tight fight once you have the heatsink in.
4. Will the heatsink actually fit within the case since its a mid tower case.
