- Jul 26, 2001
- Houston, TX
Any help or pointers in the right direction would be appreciated.
Ok I can get this program to work if I put it all into 1 *.cpp file and compile it, it works perfect. But I am having trouble if I try to seperate it into a Proj1_prototype.cpp file and a Proj1_prototype.h file. The main problem I am havinf is that it does not seem to recognize the "string" types in my struct. Here are some of the errors I am getting.
--------------------Configuration: CS_Project - Win32 Debug--------------------
Compiling...
Proj1_prototype.cpp
F:\CS 2310\Proj1\Proj1_prototype.h(13) : error C2146: syntax error : missing ';' before identifier 'Name'
F:\CS 2310\Proj1\Proj1_prototype.h(13) : error C2501: 'string' : missing storage-class or type specifiers
F:\CS 2310\Proj1\Proj1_prototype.h(13) : error C2501: 'Name' : missing storage-class or type specifiers
F:\CS 2310\Proj1\Proj1_prototype.h(14) : error C2146: syntax error : missing ';' before identifier 'ssn'
F:\CS 2310\Proj1\Proj1_prototype.h(14) : error C2501: 'string' : missing storage-class or type specifiers
F:\CS 2310\Proj1\Proj1_prototype.h(14) : error C2501: 'ssn' : missing storage-class or type specifiers
F:\CS 2310\Proj1\Proj1_prototype.cpp(71) : error C2039: 'Name' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.h(12) : see declaration of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(75) : error C2039: 'ssn' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(108) : error C2039: 'Name' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(112) : error C2039: 'ssn' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(145) : error C2039: 'Name' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(149) : error C2039: 'ssn' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(182) : error C2039: 'Name' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(186) : error C2039: 'ssn' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(219) : error C2039: 'Name' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(223) : error C2039: 'ssn' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(302) : error C2039: 'Name' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(306) : error C2039: 'ssn' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(340) : error C2039: 'Name' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(344) : error C2039: 'ssn' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(378) : error C2039: 'Name' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(382) : error C2039: 'ssn' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(416) : error C2039: 'Name' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(420) : error C2039: 'ssn' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(505) : error C2039: 'Name' : is not a member of 'StudentRecord'
F:\CS 2310\Proj1\Proj1_prototype.cpp(506) : error C2039: 'ssn' : is not a member of 'StudentRecord'
Error executing cl.exe.
Proj1_prototype.obj - 26 error(s), 0 warning(s)
Here are the files
Proj1_prototype.cpp
// CS2310 Project 1 Implementation file
#include <iostream>
#include <fstream>
#include <string>
#include "Proj1_prototype.h"
using namespace std;
void StuRecords::InsertRecord(StudentRecord& newRecord)
data[length] = newRecord;
length++;
void StuRecords:rintByGrades() const
// Postcondition:
// Print out student records by the letter grades, with the records
// of 'A' first, 'B' the second, ..., 'F' the last.
//************* Opens file for writing *******
ofstream fout;
fout.open ("f:/gfile.txt");
if ( fout.fail() )
cout<< "Output file opening failed.\n";
exit(1);
int i;
int j;
fout.width(LEN_SPACING_NAME);
fout.setf(ios::left);
fout<<"Name";
fout.width(LEN_SPACING_SSN);
fout<<"Student ID";
fout.width(LEN_SPACING_RANK);
fout<<"Rank";
fout<<"Grade"<<endl;
for ( i = 0; i < 5; i++)
if (i == 0)
for (j = 0; j < length; j++)
if (data[j].letterGrade == A)
fout<<data[j].Name;
fout<<data[j].ssn;
switch (data[j].rank)
case Freshman: fout.width(LEN_SPACING_RANK);
fout<<"Freshman";
break;
case Sophomore: fout.width(LEN_SPACING_RANK);
fout<<"Sophomore";
break;
case Junior: fout.width(LEN_SPACING_RANK);
fout<<"Junior";
break;
case Senior: fout.width(LEN_SPACING_RANK);
fout<<"Senior";
break;
fout<<'A'<<endl;
if ( i == 1)
if (data[j].letterGrade == B)
fout<<data[j].Name;
fout<<data[j].ssn;
fout<<"Freshman";
break;
fout<<"Sophomore";
break;
fout<<"Junior";
break;
fout<<"Senior";
break;
fout<<'B'<<endl;
if ( i ==2)
if (data[j].letterGrade == C)
fout<<data[j].Name;
fout<<data[j].ssn;
fout<<"Freshman";
break;
fout<<"Sophomore";
break;
fout<<"Junior";
break;
fout<<"Senior";
break;
fout<<'C'<<endl;
if (i == 3)
if (data[j].letterGrade == D)
fout<<data[j].Name;
fout<<data[j].ssn;
fout<<"Freshman";
break;
fout<<"Sophomore";
break;
fout<<"Junior";
break;
fout<<"Senior";
break;
fout<<'D'<<endl;
if (i == 4)
if (data[j].letterGrade == F)
fout<<data[j].Name;
fout<<data[j].ssn;
fout<<"Freshman";
break;
fout<<"Sophomore";
break;
fout<<"Junior";
break;
fout<<"Senior";
break;
fout<<'F'<<endl;
fout<<endl;
fout.close();
void StuRecords:rintByRanks() const
// Postcondition:
// Print out student records by their classification, with the records
// of "Freshman" first, "Junior" second, ..., Senior the last.
//******* Opens file for writing & appends ***
ofstream fout;
fout.open ("f:/gfile.txt", ios::app);
if ( fout.fail() )
exit(1);
int i;
int j;
fout<<"Name";
fout<<"Student ID";
fout<<"Rank";
for ( i = 0; i < 4; i++)
if (i == 0)
if (data[j].rank == Freshman)
fout<<data[j].Name;
fout<<data[j].ssn;
fout<<"Freshman";
switch (data[j].letterGrade)
case A: fout.setf(ios::left);
fout<<'A'<<endl;
break;
case B: fout.setf(ios::left);
fout<<'B'<<endl;
break;
case C: fout.setf(ios::left);
fout<<'C'<<endl;
break;
case D: fout.setf(ios::left);
fout<<'D'<<endl;
break;
case F: fout.setf(ios::left);
fout<<'F'<<endl;
break;
if ( i == 1)
if (data[j].rank == Sophomore)
fout<<data[j].Name;
fout<<data[j].ssn;
fout<<"Sophomore";
fout<<'A'<<endl;
break;
fout<<'B'<<endl;
break;
fout<<'C'<<endl;
break;
fout<<'D'<<endl;
break;
fout<<'F'<<endl;
break;
if ( i ==2)
if (data[j].rank == Junior)
fout<<data[j].Name;
fout<<data[j].ssn;
fout<<"Junior";
fout<<'A'<<endl;
break;
fout<<'B'<<endl;
break;
fout<<'C'<<endl;
break;
fout<<'D'<<endl;
break;
fout<<'F'<<endl;
break;
if (i == 3)
if (data[j].rank == Senior)
fout<<data[j].Name;
fout<<data[j].ssn;
fout<<"Senior";
fout<<'A'<<endl;
break;
fout<<'B'<<endl;
break;
fout<<'C'<<endl;
break;
fout<<'D'<<endl;
break;
fout<<'F'<<endl;
break;
fout.close();
StuRecords::StuRecords() {
// Default constructor: Zero the length of the array.
length = 0;
//******************** Main Function ************************************
int main() {
StudentRecord recordTemp;
StuRecords CurrentRecords;
int numberOfRecords;
int i;
int classRank;
string string1, string2, string3, string4;
ifstream fin;
ofstream fout;
//********* Opens file for reading ***********
fin.open ("stuflie.txt");
if ( fin.fail() )
cout<< "Input file opening failed.\n";
exit(1);
fin>>numberOfRecords;
//********************* Assignment of records **********************
if (numberOfRecords > 0)
for ( i = 0; i < numberOfRecords; i++)
fin>> string1;
fin>> string2;
string3 = string1 + ' ' + string2;
recordTemp.Name = string3;
fin>> recordTemp.ssn;
fin>> classRank;
fin>> recordTemp.grades[0] >>recordTemp.grades[1] >> recordTemp.grades[2];
recordTemp.average = (recordTemp.grades[0] + recordTemp.grades[1] + recordTemp.grades[2])/3.0;
switch (classRank)
case 1: recordTemp.rank = Freshman;
break;
case 2: recordTemp.rank = Sophomore;
break;
case 3: recordTemp.rank = Junior;
break;
case 4: recordTemp.rank = Senior;
break;
if (recordTemp.average >= 90)
recordTemp.letterGrade = A;
else if (recordTemp.average < 90 && recordTemp.average >= 80)
recordTemp.letterGrade = B;
else if (recordTemp.average < 80 && recordTemp.average >= 75)
recordTemp.letterGrade = C;
else if (recordTemp.average < 75 && recordTemp.average >= 70)
recordTemp.letterGrade = D;
else recordTemp.letterGrade = F;
CurrentRecords.InsertRecord(recordTemp);
//******************* Function Calls *******************************
CurrentRecords.PrintByGrades();
CurrentRecords.PrintByRanks();
fin.close();
return 0;
Proj1_prototype.h
// CS2310 Project 1 Specification file
const int MAX_NUM_STUDENTS = 15;
const int LEN_SPACING_NAME = 23;
const int LEN_SPACING_SSN = 14;
const int LEN_SPACING_RANK = 12;
enum letRank {Freshman, Sophomore, Junior, Senior};
enum letGrade {A, B, C, D, F};
struct StudentRecord
string Name;
string ssn;
letRank rank;
letGrade letterGrade;
int grades[3];
int average;
class StuRecords
public:
void InsertRecord(StudentRecord& newRecord);
// Precondition:
// A new student record is passed in by newRecord.
// Postcondition:
// The new record is inserted into the bottom of the record array.
// This function assume the array is not sorted.
void PrintByGrades() const;
// Postcondition:
void PrintByRanks() const;
// Postcondition:
StuRecords();
private:
int length; // Keep track the number of students.
StudentRecord data[MAX_NUM_STUDENTS];
Thanks!!!
Compiling...
Proj1_prototype.cpp
Here are the files
Proj1_prototype.cpp
#include <iostream>
#include <fstream>
#include <string>
length++;
// Postcondition:
ofstream fout;
if ( fout.fail() )
exit(1);
int i;
int j;
fout<<"Name";
fout<<"Student ID";
fout<<"Rank";
if (i == 0)
fout<<data[j].Name;
fout<<data[j].ssn;
fout<<"Freshman";
break;
fout<<"Sophomore";
break;
fout<<"Junior";
break;
fout<<"Senior";
break;
fout<<'A'<<endl;
if ( i == 1)
fout<<data[j].Name;
fout<<data[j].ssn;
fout<<"Freshman";
break;
fout<<"Sophomore";
break;
fout<<"Junior";
break;
fout<<"Senior";
break;
fout<<'B'<<endl;
if ( i ==2)
fout<<data[j].Name;
fout<<data[j].ssn;
fout<<"Freshman";
break;
fout<<"Sophomore";
break;
fout<<"Junior";
break;
fout<<"Senior";
break;
fout<<'C'<<endl;
if (i == 3)
fout<<data[j].Name;
fout<<data[j].ssn;
fout<<"Freshman";
break;
fout<<"Sophomore";
break;
fout<<"Junior";
break;
fout<<"Senior";
break;
fout<<'D'<<endl;
if (i == 4)
fout<<data[j].Name;
fout<<data[j].ssn;
fout<<"Freshman";
break;
fout<<"Sophomore";
break;
fout<<"Junior";
break;
fout<<"Senior";
break;
fout<<'F'<<endl;
fout<<endl;
fout.close();
// Postcondition:
ofstream fout;
if ( fout.fail() )
exit(1);
int i;
int j;
fout<<"Name";
fout<<"Student ID";
fout<<"Rank";
if (i == 0)
fout<<data[j].Name;
fout<<data[j].ssn;
fout<<"Freshman";
fout<<'A'<<endl;
break;
fout<<'B'<<endl;
break;
fout<<'C'<<endl;
break;
fout<<'D'<<endl;
break;
fout<<'F'<<endl;
break;
if ( i == 1)
fout<<data[j].Name;
fout<<data[j].ssn;
fout<<"Sophomore";
fout<<'A'<<endl;
break;
fout<<'B'<<endl;
break;
fout<<'C'<<endl;
break;
fout<<'D'<<endl;
break;
fout<<'F'<<endl;
break;
if ( i ==2)
fout<<data[j].Name;
fout<<data[j].ssn;
fout<<"Junior";
fout<<'A'<<endl;
break;
fout<<'B'<<endl;
break;
fout<<'C'<<endl;
break;
fout<<'D'<<endl;
break;
fout<<'F'<<endl;
break;
if (i == 3)
fout<<data[j].Name;
fout<<data[j].ssn;
fout<<"Senior";
fout<<'A'<<endl;
break;
fout<<'B'<<endl;
break;
fout<<'C'<<endl;
break;
fout<<'D'<<endl;
break;
fout<<'F'<<endl;
break;
fout.close();
length = 0;
int main() {
int i;
int classRank;
ifstream fin;
ofstream fout;
if ( fin.fail() )
exit(1);
fin>> string1;
fin>> string2;
fin>> classRank;
switch (classRank)
break;
break;
break;
break;
fin.close();
return 0;
Proj1_prototype.h
string Name;
string ssn;
letRank rank;
int grades[3];
int average;
class StuRecords
public:
// Precondition:
// Postcondition:
// Postcondition:
// Postcondition:
StuRecords();
private:
Thanks!!!
