Will this hardware work on PC-BSD?
Edward78
Code:
*****  Start of Report  *****
<<< Server Status >>>
    Name:                          SiSoftware Sandra Lite (Win32 x86)
    Version:                       2007.6.10.99
    Copyright:                     Copyright © SiSoftware Ltd 1995-2006. All
                                   Rights Reserved.
    Registered Owner:              Nicholas James
    Licence Status:                Evaluation copy, strictly for personal/
                                   educational use only. For business/commercial
                                   use, it can be trialled for 21 days.
    Licence Extra:                 You are on day %i of your evaluation period.
                                   Please see the SiSoftware site (http://
                                   [url]www.sisoftware.net[/url]) for purchase details.
    URL:                           [url]http://www.sisoftware.net/sandra/[/url]
    E-Mail:                        [email][email protected][/email]
    Done By:                       Nicholas James
    Host Name:                     NICK
    System ID:                     {8F572BBA-31B4-4492-8A84-FB74E8AFFD91}
    Run ID:                        {589B1CAB-D0B9-4ad6-8F5E-986968D4B543}
    Done On:                       Thursday, January 04, 2007
    Done At:                       3:28:48 PM
<<< Report Comments >>>
<<< Mainboard >>>
  < System >
    Manufacturer:                  System manufacturer
    Model:                         System Product Name
    Version:                       System Version
    Serial Number:                 System Serial Number
  < System Chassis >
    Manufacturer:                  Chassis Manufacture
    Type:                          Desktop
    Can be locked:                 No
    Version:                       Chassis Version
    Serial Number:                 Chassis Serial Number
    Asset Tag:                     Asset-1234567890
    Boot-up State:                 Safe
    Power State:                   Safe
    Thermal State:                 Safe
    Security State:                External Interface Locked-out
  < Mainboard >
    Manufacturer:                  ASUSTeK Computer INC.
    MP Support:                    1 Processor(s)
    MPS Version:                   1.10
    Model:                         K8U-X
    Serial Number:                 MB-1234567890
    System BIOS:                   63-0808-000001-00101111-120505-ATHLON64
  < On-board Devices >
     Realtek 8201CL:               Ethernet Adapter (Enabled)
  < System Memory Controller >
    Error Correction Capability:   None
    Number of Memory Slots:        2
    Maximum Installable Memory:    4GB
    BANK0 - DIMM0:                 Empty
    BANK1 - DIMM1:                 Manufacturer1 PartNum1 SerNum1 AssetTagNum1
                                   DIMM Synchronous SDRAM 512MB/64
  < Chipset 1 >
    Model:                         Acer Labs Incorporated (ALi/ULi) ULi M1689 K8
                                   Northbridge with AGP and hypertransport
    Bus(es):                       ISA AGP PCI USB i2c/SMBus
    Version:                       1.04
    Front Side Bus Speed:          2x 200MHz (400MHz data rate)
    In/Out Width:                  8-bit / 8-bit
  < Logical/Chipset 1 Memory Banks >
    Memory Controller in Processor:Yes
    Power Save Mode:               No
    Fixed Hole Present:            No
  < Chipset 2 >
    Model:                         Advanced Micro Devices (AMD) Athlon 64 /
                                   Opteron HyperTransport Technology
                                   Configuration
    Version:                       1.02
    Maximum FSB Speed / Max Memory:2x 1000MHz / 2x 200MHz
    IO Queue Depth:                8 request(s)
  < Chipset 2 Hub Interface >
    Type:                          HyperTransport
    Version:                       1.02
  < Logical/Chipset 2 Memory Banks >
    Bank 2:                        512MB DDR-SDRAM 3.0-3-3-8 1CMD
    Channels:                      1
    Multiplier:                    1/11x
    Width:                         64-bit
    Cores per Memory Controller:   1 Unit(s)
    Refresh Rate:                  7.80µs
    Power Save Mode:               No
  < Memory Module 1 >
    Model:                         SUPERTALENT
    Type:                          512MB DDR-SDRAM
    Technology:                    8x(64Mx8)
    Speed:                         PC3200U 3.0-3-3-8
    Version:                       1.0
    Date of Manufacture:           Sunday, October 29, 2006
    Set Timing @ 200MHz:           3.0-3-3-8
    Set Timing @ 167MHz:           2.5-3-3-7
  < Environment Monitor 1 >
    Model:                         ITE IT8712F LPC
    Version:                       7.00
    Mainboard Specific Support:    No
  < Temperature Sensor(s) >
    Board Temperature:             32.0°C / 89.6°F
    CPU Temperature:               34.0°C / 93.2°F
  < Cooling Device(s) >
    Auto Fan Speed Control:        No
    Chassis Fan Speed:             4327rpm
    CPU Fan Speed:                 2813rpm
  < Voltage Sensor(s) >
    CPU Voltage:                   1.50V
    +3.3V Voltage:                 3.25V
    +5V Voltage:                   5.13V
    +12V Voltage:                  11.79V
  < AGP Bus(es) on Hub 1 >
    Version:                       3.00
    Speed:                         8x
    Fast-Writes Enabled:           Yes
    Isochronous Mode Enabled:      No
    Addressing Enabled:            32-bit
  < PCI Bus(es) on Hub 1 >
    Version:                       2.20
    Number of Bridges:             2
    PCI Bus 0:                     PCI (1/1x PCIClk)
    PCI Bus 2:                     PCI (1/1x PCIClk)
  < LPC Hub Controller 1 >
    Model:                         Acer Labs Incorporated (ALi/ULi) ALI M1563
                                   South Bridge with Hypertransport Support
  < USB Controller 1 >
    Model:                         ASUSTeK Computer Inc ALI M5237 OpenHCI USB
                                   Controller
    Version:                       1.00
    Interface:                     OHCI
    Channels:                      3
    Supported Speed(s):            Low (1.5Mbps) Full (12Mbps)
    Legacy Emulation Enabled:      No
  < USB Controller 2 >
                                   Controller
    Version:                       1.00
    Interface:                     OHCI
    Channels:                      3
  < USB Controller 3 >
                                   Controller
    Version:                       1.00
    Interface:                     OHCI
    Channels:                      3
  < USB Controller 4 >
    Model:                         ASUSTeK Computer Inc USB 2.0 Enhanced Host
                                   Controller
    Version:                       2.00
    Specification:                 1.00
    Interface:                     EHCI
    Channels:                      8
    Companion Controllers:         3
    Supported Speed(s):            Low (1.5Mbps) Full (12Mbps) High (480Mbps)
    Addressing Support:            32-bit
  < System SMBus Controller 1 >
    Model:                         Ali 1563 SMBus
    Specification:                 2.00
    Advanced TCO Mode Enabled:     No
    Slave Device Enabled:          No
    PEC Support:                   No
    Speed:                         55kHz
  < Expansion Slot(s) >
    AGP:                           AGP-8x 32-bit +3.3V Shared PME Half-Length
                                   Available
    PCI1 (1h):                     PCI 32-bit +3.3V Shared PME Half-Length
                                   Available (Acer Labs Incorporated (ALi/ULi)
                                   ULi AGP 3.0 Controller)
    PCI2 (2h):                     PCI 32-bit +3.3V Shared PME Half-Length
                                   ALI HTT to PCI Bridge)
    PCI3 (3h):                     PCI 32-bit +3.3V Shared PME Half-Length
                                   ALI M1563 South Bridge with Hypertransport
                                   Support)
    PCI4 (4h):                     PCI 32-bit +3.3V Shared PME Half-Length
                                   Available (ASUSTeK Computer Inc ALI M5455
                                   AC'97 Audio)
  < Port Connector(s) >
    PS/2Mouse - PS/2Mouse:         Mouse - None / PS/2
    PS/2Keyboard - PS/2Keyboard:   Keyboard - None / PS/2
    USB1 - USB1:                   USB - None / USB
    USB2 - USB2:                   USB - None / USB
    USB3 - USB3:                   USB - None / USB
    USB4 - USB4:                   USB - None / USB
    USB5 - USB5:                   USB - None / USB
    USB6 - USB6:                   USB - None / USB
    USB7 - USB7:                   USB - None / USB
    USB8 - USB8:                   USB - None / USB
    LPT - LPT 1:                   Parallel Port ECP/EPP - None / DB-25 pin male
    COM - COM A:                   Serial Port 16550A - None / DB-9 pin male
    MIDI - MIDI:                   MIDI - None / DB-15 pin female
    Joy Stick - Joy Stick:         Joystick - None / DB-15 pin female
    Mic In - Audio Mic In:         Audio - None / Mini-jack
    Line In - Audio Line In:       Audio - None / Mini-jack
    Line Out - Audio Line Out:     Audio - None / Mini-jack
    LAN - LAN:                     Network - None / RJ-45
    AUX:                           Audio - CD-ROM Sound Input / None
    CD:                            Audio - CD-ROM Sound Input / None
    PRI IDE:                       None - ATA / None
    SEC IDE:                       None - ATA / None
    FLOPPY:                        None - Floppy Disk / None
    CHASSIS FAN:                   None - None / None
    CPU FAN:                       None - None / None
    POWER FAN:                     None - None / None
    ATXPWR:                        None - None / None
    CHASSIS:                       None - None / None
    FP AUDIO:                      None - None / None
    SATA1:                         None - None / None
    SATA2:                         None - None / None
  < Performance Tips >
    Warning 2533:                  Disabled host controllers are present. Check
                                   BIOS settings.
    Tip 2530:                      MPS 1.4 or later is recommended for MP
                                   systems. Check BIOS version.
    Notice 224:                    SMBIOS/DMI information may be inaccurate.
    Warning 2507:                  Mainboard has too few memory slots. Upgrading
                                   the memory may be difficult or expensive.
    Tip 2511:                      Some memory slots are free so the memory can
                                   be easily upgraded.
    Warning 100:                   Large memory sizes should be made of
                                   Registered/Buffered memory.
    Tip 2546:                      Large memory modules should be ECC/Parity.
    Tip 2:                         Double-click tip or press Enter while a tip
                                   is selected for more information about the
                                   tip.
<<< Mainboard Configuration >>>
<< System BIOS >>
  < General Information >
    Manufacturer:                  American Megatrends Inc.
    Version:                       0808
    Date of Manufacture:           Monday, December 05, 2005
    Plug & Play Version:           1.00
    SMBIOS/DMI Version:            2.30
    (EE)PROM Size:                 512kB
  < General Capabilities >
    Can be Updated/Flashed:        Yes
    Can be Shadowed:               Yes
    Is Socketed:                   Yes
    Supports Plug & Play:          Yes
    Supports ESCD:                 Yes
    Supports Enhanced Disk Drive:  Yes
    NEC PC-98 Spec Compatible:     No
  < Power Management Features >
    Supports APM:                  Yes
    Supports ACPI:                 Yes
    Supports Smart Battery:        No
  < Boot Features >
    Supports Selective Booting:    Yes
    Supports CD/DVD Boot:          Yes
    Supports PCMCIA/CardBus Boot:  No
    Supports LS-120 Boot:          Yes
    Supports ZIP Boot:             Yes
    Supports i2o Boot:             No
    Supports FireWire/1394 Boot:   No
    Supports BIOS Boot Block:      Yes
    Supports Interactive Network B:No
    Tip 212:                       BIOS can be shadowed so check whether it is.
    Tip 211:                       BIOS is flash-able and socketed so it can be
                                   upgraded when needed.
                                   tip.
<<< Processors >>>
<< CPU 1 [Processor 0, Core 0, Thread 0] >>
  < Processor >
    Model:                         AMD Athlon(tm) 64 Processor 3200+
    Speed:                         2.20GHz
    Model Number:                  3200 (estimated)
    Performance Rating:            PR3300 (estimated)
    Cores per Processor:           1 Unit(s)
    Threads per Core:              1 Unit(s)
    Package:                       FC µPGA754
    Multiplier:                    11/1x
    Minimum/Maximum Multiplier:    11/1x / 11/1x
    Generation:                    G8
    Name:                          MC-DH Athlon 64 (K8 Newcastle) 130nm 1.6-
                                   2.4GHz 1.45-1.55V
    Revision/Stepping:             C / 0 (10A)
    Stepping Mask:                 DH-CG
    Microcode:                     MU0FC03A
    Core Voltage Rating:           1.500V
    Min/Max Core Voltage:          1.500V / 1.550V
    Maximum Physical / Virtual Add:40-bit / 48-bit
    Native Page Size:              4kB
    Part Number:                   To Be Filled By O.E.M.
    Asset Tag:                     To Be Filled By O.E.M.
    Serial Number:                 To Be Filled By O.E.M.
  < Co-Processor (FPU) >
    Type:                          Built-in
  < Processor Cache(s) >
    Internal Data Cache:           64kB Synchronous, Write-Back, 2-way set, 64
                                   byte line size
    Internal Instruction Cache:    64kB Synchronous, Write-Back, 2-way set, 64
                                   byte line size
    L2 On-board Cache:             512kB ECC Synchronous, Write-Back, 16-way set,
                                    64 byte line size
    L2 Cache Multiplier:           1/1x  (2200MHz)
  < Upgradeability >
    Socket/Slot:                   CPU 1
    Upgrade Interface:             Socket 754
    Supported Speed(s):            2.20GHz+
    Version:                       7.00
  < Power Rating(s) >
    CPU Core Power:                84W (estimated)
    CPU Cooling System Thermal Res:0.01°C/W (estimated)
  < Sensors >
    CPU Voltage:                   1.52V
  < Features >
    FPU - Co-Processor Built-in:   Yes
    VME - Virtual Mode Extensions: Yes
    DE - Debugging Extension:      Yes
    PSE - Page Size Extension:     Yes
    TSC - Time Stamp Counter:      Yes
    MSR - Model Specific Registers:Yes
    PAE - Physical Address Extensi:Yes
    MCE - Machine Check Exception: Yes
    CX8 - Compare & Exchange 8-byt:Yes
    APIC - Local APIC Built-in:    Yes
    SEP - Fast System Call:        Yes
    MTRR - Memory Type Range Regis:Yes
    PGE - Page Global Enable:      Yes
    MCA - Machine Check Architectu:Yes
    PAT - Page Attribute Table:    Yes
    PSE36 - 36-bit Page Size Exten:Yes
    PSN - Unique Serial Number:    No
    CLF - Cache Line Flush Support:Yes
    DS - Debug Trace & EMON Store: No
    ACPI - Software Clock Control: No
    (W)MMX Technology:             Yes
    FXSR - Fast Float Save & Resto:Yes
    SSE Technology:                Yes
    SSE2 Technology:               Yes
    SS - Self Snoop:               No
    HTT - Hyper-Threading Technolo:No
    TM - Thermal Monitor:          No
    PBE - Pending Break Enable:    No
    IA64 Technology:               No
    SSE3 Technology:               No
    MON - Monitor/MWait:           No
    DSCPL - CPL qualified Debug St:No
    VMX - Virtual Machine eXtensio:No
    EST - Enhanced SpeedStep Techn:No
    TM2 - Thermal Monitor 2:       No
    SSE4 Technology:               No
    CID - Context ID:              No
    CX16 - Compare & Exchange 16-b:No
    xTPR - Send Task Priority Mess:No
    DAZ - Denormals Are Zero:      Yes
  < Extended Features >
    SYCR - Extended Fast System Ca:Yes
    EMMX - Extended MMX Technology:Yes
    FXSR - Instructions Optimisati:No
    3DNow! Technology:             Yes
    Extended 3DNow! Technology:    Yes
    XD/NX - No-execute Page Protec:Yes
    AMD64/EM64T Technology:        Yes
    RDTSCP - Serialised TSC:       No
    LAHF/SAHF - Support in 64-bit: No
    CMP - Multi-Core Legacy Mode:  No
    SVM - Secure Virtual Machine:  No
    APICEX - Extended APIC Registe:No
    3D Now! Prefetch Technology:   No
    100MHz - Half Multiplier Suppo:No
    STC - Software Thermal Control:No
    TTP - Thermal Trip:            Yes
    VID - Voltage Control:         Yes
    FID - Frequency Control:       Yes
    TS - Thermal Sensor Built-in:  Yes
  < Advanced Settings >
    System Ack Limit:              1 request(s)
    System Victim Limit:           0 request(s)
    Extended MTRR Types:           Yes
    I/O Type Range Registers:      Yes
    Top of Memory:                 20000000 (512MB)
  < Machine Check Architecture Settings >
    Number of Reporting Banks:     5 bank(s)
    Exception Reporting Control Su:Yes
  < Variable Range MTRR Settings >
    MTRR 0:                        00000000-1FFFFFFF (0MB-512MB) WB
  < Variable Range IORR Settings >
  < Fixed Range MTRR Settings >
    MTRR 0 Range 0:                00000000-0000FFFF (0kB-64kB) WB rdIO wrIO
    MTRR 0 Range 1:                00010000-0001FFFF (64kB-128kB) WB rdIO wrIO
    MTRR 0 Range 2:                00020000-0002FFFF (128kB-192kB) WB rdIO wrIO
    MTRR 0 Range 3:                00030000-0003FFFF (192kB-256kB) WB rdIO wrIO
    MTRR 0 Range 4:                00040000-0004FFFF (256kB-320kB) WB rdIO wrIO
    MTRR 0 Range 5:                00050000-0005FFFF (320kB-384kB) WB rdIO wrIO
    MTRR 0 Range 6:                00060000-0006FFFF (384kB-448kB) WB rdIO wrIO
    MTRR 0 Range 7:                00070000-0007FFFF (448kB-512kB) WB rdIO wrIO
    MTRR 1 Range 0:                00080000-00083FFF (512kB-528kB) WB rdIO wrIO
    MTRR 1 Range 1:                00084000-00087FFF (528kB-544kB) WB rdIO wrIO
    MTRR 1 Range 2:                00088000-0008BFFF (544kB-560kB) WB rdIO wrIO
    MTRR 1 Range 3:                0008C000-0008FFFF (560kB-576kB) WB rdIO wrIO
    MTRR 1 Range 4:                00090000-00093FFF (576kB-592kB) WB rdIO wrIO
    MTRR 1 Range 5:                00094000-00097FFF (592kB-608kB) WB rdIO wrIO
    MTRR 1 Range 6:                00098000-0009BFFF (608kB-624kB) WB rdIO wrIO
    MTRR 1 Range 7:                0009C000-0009FFFF (624kB-640kB) WB rdIO wrIO
    MTRR 2 Range 0:                000A0000-000A3FFF (640kB-656kB) UC rdIO wrIO
    MTRR 2 Range 1:                000A4000-000A7FFF (656kB-672kB) UC rdIO wrIO
    MTRR 2 Range 2:                000A8000-000ABFFF (672kB-688kB) UC rdIO wrIO
    MTRR 2 Range 3:                000AC000-000AFFFF (688kB-704kB) UC rdIO wrIO
    MTRR 2 Range 4:                000B0000-000B3FFF (704kB-720kB) UC rdIO wrIO
    MTRR 2 Range 5:                000B4000-000B7FFF (720kB-736kB) UC rdIO wrIO
    MTRR 2 Range 6:                000B8000-000BBFFF (736kB-752kB) UC rdIO wrIO
    MTRR 2 Range 7:                000BC000-000BFFFF (752kB-768kB) UC rdIO wrIO
    MTRR 3 Range 0:                000C0000-000C0FFF (768kB-772kB) UC rdIO wrIO
    MTRR 3 Range 1:                000C1000-000C1FFF (772kB-776kB) UC rdIO wrIO
    MTRR 3 Range 2:                000C2000-000C2FFF (776kB-780kB) UC rdIO wrIO
    MTRR 3 Range 3:                000C3000-000C3FFF (780kB-784kB) UC rdIO wrIO
    MTRR 3 Range 4:                000C4000-000C4FFF (784kB-788kB) UC rdIO wrIO
    MTRR 3 Range 5:                000C5000-000C5FFF (788kB-792kB) UC rdIO wrIO
    MTRR 3 Range 6:                000C6000-000C6FFF (792kB-796kB) UC rdIO wrIO
    MTRR 3 Range 7:                000C7000-000C7FFF (796kB-800kB) UC rdIO wrIO
    MTRR 4 Range 0:                000C8000-000C8FFF (800kB-804kB) UC rdIO wrIO
    MTRR 4 Range 1:                000C9000-000C9FFF (804kB-808kB) UC rdIO wrIO
    MTRR 4 Range 2:                000CA000-000CAFFF (808kB-812kB) UC rdIO wrIO
    MTRR 4 Range 3:                000CB000-000CBFFF (812kB-816kB) UC rdIO wrIO
    MTRR 4 Range 4:                000CC000-000CCFFF (816kB-820kB) UC rdIO wrIO
    MTRR 4 Range 5:                000CD000-000CDFFF (820kB-824kB) UC rdIO wrIO
    MTRR 4 Range 6:                000CE000-000CEFFF (824kB-828kB) UC rdIO wrIO
    MTRR 4 Range 7:                000CF000-000CFFFF (828kB-832kB) UC rdIO wrIO
    MTRR 5 Range 0:                000D0000-000D0FFF (832kB-836kB) UC rdIO wrIO
    MTRR 5 Range 1:                000D1000-000D1FFF (836kB-840kB) UC rdIO wrIO
    MTRR 5 Range 2:                000D2000-000D2FFF (840kB-844kB) UC rdIO wrIO
    MTRR 5 Range 3:                000D3000-000D3FFF (844kB-848kB) UC rdIO wrIO
    MTRR 5 Range 4:                000D4000-000D4FFF (848kB-852kB) UC rdIO wrIO
    MTRR 5 Range 5:                000D5000-000D5FFF (852kB-856kB) UC rdIO wrIO
    MTRR 5 Range 6:                000D6000-000D6FFF (856kB-860kB) UC rdIO wrIO
    MTRR 5 Range 7:                000D7000-000D7FFF (860kB-864kB) UC rdIO wrIO
    MTRR 6 Range 0:                000D8000-000D8FFF (864kB-868kB) UC rdIO wrIO
    MTRR 6 Range 1:                000D9000-000D9FFF (868kB-872kB) UC rdIO wrIO
    MTRR 6 Range 2:                000DA000-000DAFFF (872kB-876kB) UC rdIO wrIO
    MTRR 6 Range 3:                000DB000-000DBFFF (876kB-880kB) UC rdIO wrIO
    MTRR 6 Range 4:                000DC000-000DCFFF (880kB-884kB) UC rdIO wrIO
    MTRR 6 Range 5:                000DD000-000DDFFF (884kB-888kB) UC rdIO wrIO
    MTRR 6 Range 6:                000DE000-000DEFFF (888kB-892kB) UC rdIO wrIO
    MTRR 6 Range 7:                000DF000-000DFFFF (892kB-896kB) UC rdIO wrIO
    MTRR 7 Range 0:                000E0000-000E0FFF (896kB-900kB) UC rdIO wrIO
    MTRR 7 Range 1:                000E1000-000E1FFF (900kB-904kB) UC rdIO wrIO
    MTRR 7 Range 2:                000E2000-000E2FFF (904kB-908kB) UC rdIO wrIO
    MTRR 7 Range 3:                000E3000-000E3FFF (908kB-912kB) UC rdIO wrIO
    MTRR 7 Range 4:                000E4000-000E4FFF (912kB-916kB) UC rdIO wrIO
    MTRR 7 Range 5:                000E5000-000E5FFF (916kB-920kB) UC rdIO wrIO
    MTRR 7 Range 6:                000E6000-000E6FFF (920kB-924kB) UC rdIO wrIO
    MTRR 7 Range 7:                000E7000-000E7FFF (924kB-928kB) UC rdIO wrIO
    MTRR 8 Range 0:                000E8000-000E8FFF (928kB-932kB) UC rdIO wrIO
    MTRR 8 Range 1:                000E9000-000E9FFF (932kB-936kB) UC rdIO wrIO
    MTRR 8 Range 2:                000EA000-000EAFFF (936kB-940kB) UC rdIO wrIO
    MTRR 8 Range 3:                000EB000-000EBFFF (940kB-944kB) UC rdIO wrIO
    MTRR 8 Range 4:                000EC000-000ECFFF (944kB-948kB) UC rdIO wrIO
    MTRR 8 Range 5:                000ED000-000EDFFF (948kB-952kB) UC rdIO wrIO
    MTRR 8 Range 6:                000EE000-000EEFFF (952kB-956kB) UC rdIO wrIO
    MTRR 8 Range 7:                000EF000-000EFFFF (956kB-960kB) UC rdIO wrIO
    MTRR 9 Range 0:                000F0000-000F0FFF (960kB-964kB) WP rdIO wrIO
    MTRR 9 Range 1:                000F1000-000F1FFF (964kB-968kB) WP rdIO wrIO
    MTRR 9 Range 2:                000F2000-000F2FFF (968kB-972kB) WP rdIO wrIO
    MTRR 9 Range 3:                000F3000-000F3FFF (972kB-976kB) WP rdIO wrIO
    MTRR 9 Range 4:                000F4000-000F4FFF (976kB-980kB) WP rdIO wrIO
    MTRR 9 Range 5:                000F5000-000F5FFF (980kB-984kB) WP rdIO wrIO
    MTRR 9 Range 6:                000F6000-000F6FFF (984kB-988kB) WP rdIO wrIO
    MTRR 9 Range 7:                000F7000-000F7FFF (988kB-992kB) WP rdIO wrIO
    MTRR 10 Range 0:               000F8000-000F8FFF (992kB-996kB) WP rdIO wrIO
    MTRR 10 Range 1:               000F9000-000F9FFF (996kB-1000kB) WP rdIO wrIO
    MTRR 10 Range 2:               000FA000-000FAFFF (1000kB-1004kB) WP rdIO
                                   wrIO
    MTRR 10 Range 3:               000FB000-000FBFFF (1004kB-1008kB) WP rdIO
                                   wrIO
    MTRR 10 Range 4:               000FC000-000FCFFF (1008kB-1012kB) WP rdIO
                                   wrIO
    MTRR 10 Range 5:               000FD000-000FDFFF (1012kB-1016kB) WP rdIO
                                   wrIO
    MTRR 10 Range 6:               000FE000-000FEFFF (1016kB-1020kB) WP rdIO
                                   wrIO
    MTRR 10 Range 7:               000FF000-000FFFFF (1020kB-1024kB) WP rdIO
                                   wrIO
  < PAT Settings >
    PAT 0:                         WB
    PAT 1:                         WC
    PAT 2:                         UC-
    PAT 3:                         UC
    PAT 4:                         WB
    PAT 5:                         WC
    PAT 6:                         UC-
    PAT 7:                         UC
                                   BIOS settings.
                                   tip.
<<< Buses and Devices >>>
<< Generic >>
<< Interface >>
  < System Buses >
    AGP Bus(es):                   1
    PCI Bus(es):                   2
    Interface Version:             2.20
  < Interface Properties >
    Config space access mechanism :Yes
    Config space access mechanism :No
    Cycle generation mechanism 1 s:No
    Cycle generation mechanism 2 s:No
<< PCI Bus 0 (1/1x PCIClk) >>
<< Acer Labs Incorporated (ALi/ULi) ULi M1689 K8 Northbridge with AGP and
hypertransport >>
  < Device Information >
    Device Type:                   Host Processor Bridge
    Device ID:                     bus 0, device 0, function 0
    Windows Device Name:           PCI standard host CPU bridge
    OEM Device Name:               Acer Labs Incorporated (ALi/ULi) ULi M1689 K8
    OEM Hardware ID:               FUN_0, VEN_10B9, DEV_1689, REV_00
    Revision:                      A / 1 (0)
  < HyperTransport Capabilities >
    Slave/Primary Interface:       Yes
    Version:                       1.04
    Master Host:                   No
    Default Direction:             No
    Unit Count:                    1
    Base UnitID:                   0
    End of Chain:                  No
    Interrupt Discovery & Configur:Yes
  < AGP Capabilities >
    Version:                       3.00
    Command Queue Length:          28
    Fast-Writes Support:           Yes
    Over 4GB Addressing Support:   No
    Isochronous Mode Support:      No
    Data Transfer Modes Support:   4x 8x
  < Device Capabilities >
    I/O Range:                     No
    Memory Range:                  Yes
    Bus Master Capable:            Yes
    Special Cycle Recognition:     No
    Memory Write & Invalidate:     No
    VGA Palette Snoop:             No
    Parity Error Response:         No
    Address/Data Stepping:         No
    System Error Line:             Yes
    Fast back-to-back Transactions:No
    Detects Parity Errors:         No
    Supports System Error Line:    No
    Supports Parity Line:          No
    User Defined Format:           No
    66MHz Bus Support:             No
    New Capability List:           Yes
    Device Select Timing:          Fast
    Multi-Function Device:         No
    Header:                        00
    Interface:                     00
  < Hardware Resources >
    Memory Range:                  D0000000
    Dynamic Management:            Yes
<< Acer Labs Incorporated (ALi/ULi) ULi AGP 3.0 Controller >>
    Device Type:                   PCI to PCI Bridge
    Device ID:                     bus 0, device 1, function 0
    Windows Device Name:           ALi PCI to AGP Controller
    OEM Device Name:               Acer Labs Incorporated (ALi/ULi) ULi AGP 3.0
                                   Controller
    OEM Hardware ID:               FUN_0, VEN_10B9, DEV_5246, REV_00
    Revision:                      A / 1 (0)
    I/O Range:                     Yes
    Memory Range:                  Yes
    66MHz Bus Support:             Yes
    New Capability List:           No
    Header:                        01
    Interface:                     00
  < Bridge Settings >
    Primary Bus No.:               0
    Secondary Bus No.:             1
    Subordinate Bus No.:           1
    Decoding:                      Positive
<< Acer Labs Incorporated (ALi/ULi) ALI HTT to PCI Bridge >>
    Device ID:                     bus 0, device 2, function 0
    Windows Device Name:           PCI standard PCI-to-PCI bridge
    OEM Device Name:               Acer Labs Incorporated (ALi/ULi) ALI HTT to
                                   PCI Bridge
    OEM Hardware ID:               FUN_0, VEN_10B9, DEV_5249, REV_00
    Revision:                      A / 1 (0)
    I/O Range:                     Yes
    Memory Range:                  Yes
    Header:                        01
    Interface:                     00
  < Bridge Settings >
    Primary Bus No.:               0
    Secondary Bus No.:             2
    Subordinate Bus No.:           2
    Decoding:                      Positive
<< Acer Labs Incorporated (ALi/ULi) ALI M1563 South Bridge with Hypertransport
Support >>
    Device Type:                   PCI to ISA Bridge
    Device ID:                     bus 0, device 3, function 0
    OEM Device Name:               Acer Labs Incorporated (ALi/ULi) ALI M1563
    OEM Hardware ID:               FUN_0, VEN_10B9, DEV_1563, REV_70
    Product ID:                    VEN_10B9, DEV_1563
    Revision:                      H / 1 (112)
    I/O Range:                     Yes
    Memory Range:                  Yes
    Special Cycle Recognition:     Yes
    Device Select Timing:          Medium
    Multi-Function Device:         Yes
    Header:                        00
    Interface:                     00
<< Acer Labs Incorporated (ALi/ULi) ALI M7101 Power Management Controller >>
    Device Type:                   Other Bridge
    Device ID:                     bus 0, device 3, function 1
    Windows Device Name:           ALi 7101 Power Management Controller
    OEM Device Name:               Acer Labs Incorporated (ALi/ULi) ALI M7101
    OEM Hardware ID:               FUN_1, VEN_10B9, DEV_7101, REV_00
    Product ID:                    VEN_10B9, DEV_7101
    Revision:                      A / 1 (0)
    I/O Range:                     No
    Memory Range:                  No
    Bus Master Capable:            No
    Header:                        00
    Interface:                     00
<< ASUSTeK Computer Inc ALI M5455 AC'97 Audio >>
    Device Type:                   Audio Multimedia Device
    Device ID:                     bus 0, device 4, function 0
    Windows Device Name:           SoundMAX Integrated Digital Audio
    OEM Device Name:               Acer Labs Incorporated (ALi/ULi) ALI M5455
                                   AC'97 Audio
    OEM Hardware ID:               FUN_0, VEN_10B9, DEV_5455, REV_20
    Device Name:                   ASUSTeK Computer Inc ALI M5455 AC'97 Audio
    Product ID:                    VEN_1043, DEV_810D
    Revision:                      C / 1 (32)
    Version:                       2.00
    Supports Clock Slow-down:      Yes
    Supports D1 PM State:          Yes
    Supports D2 PM State:          Yes
    Supports PME#:                 Yes
    Supports PME Clock:            No
    Line Cache Size:               16 byte(s)
    Latency Timer:                 64 clk
    I/O Range:                     Yes
    Memory Range:                  Yes
    Memory Write & Invalidate:     Yes
    Header:                        00
    Interface:                     00
    I/O Range:                     0000C800
    Memory Range:                  FAEFF000
    Irq. No.:                      18
    INT Pin:                       A#
<< ASUSTeK Computer Inc ULi M5263 Fast Ethernet Controller >>
    Device Type:                   Ethernet Network
    Device ID:                     bus 0, device D, function 0
    Windows Device Name:           ULi PCI Fast Ethernet Controller
    OEM Device Name:               Acer Labs Incorporated (ALi/ULi) ULi M5263
    OEM Hardware ID:               FUN_0, VEN_10B9, DEV_5263, REV_40
    Device Name:                   ASUSTeK Computer Inc ULi M5263 Fast Ethernet
                                   Controller
    Product ID:                    VEN_1043, DEV_816A
    Revision:                      E / 1 (64)
    Version:                       2.00
    Supports D1 PM State:          No
    Supports D2 PM State:          No
    Supports PME#:                 Yes
    I/O Range:                     Yes
    Memory Range:                  Yes
    Header:                        00
    Interface:                     00
    I/O Range:                     0000C400
    Memory Range:                  FAEFEC00
    Irq. No.:                      17
    INT Pin:                       A#
<< Acer Labs Incorporated (ALi/ULi) ALI M5229 EIDE Controller >>
    Device Type:                   ATA Disk Controller
    Device ID:                     bus 0, device E, function 0
    Windows Device Name:           ALi M5229 PCI Bus Master IDE Controller
    OEM Device Name:               Acer Labs Incorporated (ALi/ULi) ALI M5229
                                   EIDE Controller
    OEM Hardware ID:               FUN_0, VEN_10B9, DEV_5229, REV_C7
                                   EIDE Controller
    Product ID:                    VEN_10B9, DEV_5229
    Revision:                      M / 8 (199)
    Version:                       2.00
    Supports PME#:                 No
    Latency Timer:                 32 clk
    I/O Range:                     Yes
    Memory Range:                  No
    Header:                        00
    Interface:                     FA
    I/O Range:                     0000FF00
    INT Pin:                       A#
    I/O Range:                     000001F0
    Irq. No.:                      14
    I/O Range:                     00000170
    Irq. No.:                      15
<< ASUSTeK Computer Inc ALi M5289 SATA/RAID Controller >>
    Device Type:                   Other Disk Controller
    Device ID:                     bus 0, device E, function 1
    Windows Device Name:           ALi SATA/RAID Controller (M5289)
    OEM Device Name:               Acer Labs Incorporated (ALi/ULi) ALi M5289
    OEM Hardware ID:               FUN_1, VEN_10B9, DEV_5289, REV_10
    Device Name:                   ASUSTeK Computer Inc ALi M5289 SATA/RAID
                                   Controller
    Product ID:                    VEN_1043, DEV_816B
    Revision:                      B / 1 (16)
    Line Cache Size:               128 byte(s)
    Latency Timer:                 128 clk
    I/O Range:                     Yes
    Memory Range:                  No
    Header:                        00
    Interface:                     8F
    I/O Range:                     0000CC00
    I/O Range:                     0000C080
    I/O Range:                     0000C000
    I/O Range:                     0000BC00
    I/O Range:                     0000B880
    Irq. No.:                      19
    INT Pin:                       A#
    Warning 1206:                  PCI latency too high. Device could hog the
                                   bus for too long.
                                   tip.
<< ASUSTeK Computer Inc ALI M5237 OpenHCI USB Controller >>
    Device Type:                   Universal Serial Bus Controller
    Device ID:                     bus 0, device F, function 0
    Windows Device Name:           ALi PCI to USB Open Host Controller
    OEM Device Name:               Acer Labs Incorporated (ALi/ULi) ALI M5237
    OEM Hardware ID:               FUN_0, VEN_10B9, DEV_5237, REV_03
    Device Name:                   ASUSTeK Computer Inc ALI M5237 OpenHCI USB
                                   Controller
    Revision:                      A / 4 (3)
    I/O Range:                     Yes
    Memory Range:                  Yes
    Header:                        00
    Interface:                     10
    Memory Range:                  FAEF3000
    Irq. No.:                      20
    INT Pin:                       A#
    Device ID:                     bus 0, device F, function 1
    OEM Hardware ID:               FUN_1, VEN_10B9, DEV_5237, REV_03
                                   Controller
    Revision:                      A / 4 (3)
    I/O Range:                     Yes
    Memory Range:                  Yes
    Header:                        00
    Interface:                     10
    Memory Range:                  FAEFC000
    Irq. No.:                      21
    INT Pin:                       B#
    Device ID:                     bus 0, device F, function 2
    OEM Hardware ID:               FUN_2, VEN_10B9, DEV_5237, REV_03
                                   Controller
    Revision:                      A / 4 (3)
    I/O Range:                     Yes
    Memory Range:                  Yes
    Header:                        00
    Interface:                     10
    Memory Range:                  FAEFD000
    Irq. No.:                      22
    INT Pin:                       C#
<< ASUSTeK Computer Inc USB 2.0 Enhanced Host Controller >>
    Device ID:                     bus 0, device F, function 3
    Windows Device Name:           ULi PCI to USB Enhanced Host Controller
    OEM Device Name:               Acer Labs Incorporated (ALi/ULi) USB 2.0
    OEM Hardware ID:               FUN_3, VEN_10B9, DEV_5239, REV_01
    Device Name:                   ASUSTeK Computer Inc USB 2.0 Enhanced Host
                                   Controller
    Revision:                      A / 2 (1)
    Version:                       2.00
    Supports PME#:                 Yes
    I/O Range:                     No
    Memory Range:                  Yes
    Header:                        00
    Interface:                     20
    Memory Range:                  FAEFE800
    Irq. No.:                      23
    INT Pin:                       D#
<< Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology
Configuration >>
    Device ID:                     bus 0, device 18, function 0
    OEM Device Name:               Advanced Micro Devices (AMD) Athlon 64 /
                                   Configuration
    OEM Hardware ID:               FUN_0, VEN_1022, DEV_1100, REV_00
    Revision:                      A / 1 (0)
    Host/Secondary Interface:      Yes
    Version:                       1.02
    Double-Ended Links:            No
    Enabled:                       Yes
    Operational:                   Yes
    I/O Range:                     No
    Memory Range:                  No
    Header:                        00
    Interface:                     00
    Tip 1202:                      Device does not support bus mastering.
                                   tip.
<< Advanced Micro Devices (AMD) Athlon 64 / Opteron Address Map >>
    Device ID:                     bus 0, device 18, function 1
                                   Opteron Address Map
    OEM Hardware ID:               FUN_1, VEN_1022, DEV_1101, REV_00
    Revision:                      A / 1 (0)
    I/O Range:                     No
    Memory Range:                  No
    Header:                        00
    Interface:                     00
                                   tip.
<< Advanced Micro Devices (AMD) Athlon 64 / Opteron DRAM Controller >>
    Device ID:                     bus 0, device 18, function 2
    OEM Hardware ID:               FUN_2, VEN_1022, DEV_1102, REV_00
    Revision:                      A / 1 (0)
    I/O Range:                     No
    Memory Range:                  No
    Header:                        00
    Interface:                     00
                                   tip.
<< Advanced Micro Devices (AMD) Athlon 64 / Opteron Miscellaneous Control >>
    Device ID:                     bus 0, device 18, function 3
    OEM Hardware ID:               FUN_3, VEN_1022, DEV_1103, REV_00
    Revision:                      A / 1 (0)
    I/O Range:                     No
    Memory Range:                  No
    Header:                        00
    Interface:                     00
                                   tip.
<< AGP Bus 1 (2/1x PCIClk) >>
<< ASUSTeK Computer Inc V9570TD >>
    Device Type:                   VGA Video Adapter
    Device ID:                     bus 1, device 0, function 0
    Windows Device Name:           NVIDIA GeForce FX 5700
    OEM Device Name:               Nvidia Corp GeForce FX 5700 [NV36.2]
    OEM Hardware ID:               FUN_0, VEN_10DE, DEV_0342, REV_A1
    Device Name:                   ASUSTeK Computer Inc V9570TD
    Product ID:                    VEN_1043, DEV_814F
    Revision:                      K / 2 (161)
    Version:                       2.00
    Supports PME#:                 No
    Version:                       3.00
    Command Queue Length:          32
    Latency Timer:                 248 clk
    I/O Range:                     Yes
    Memory Range:                  Yes
    Header:                        00
    Interface:                     00
    Memory Range:                  FB000000
    Memory Range:                  E0000000
    Irq. No.:                      16
    INT Pin:                       A#
<< PCI Bus 2 (1/1x PCIClk) >>
<< No devices found. >>
    Error:                         No devices found.
<<< Power Management >>>
  < ACPI BIOS >
    Version:                       1.00
    Manufacturer:                  ACPIAM
    Revision:                      5.05
    MP APIC:                       Yes
    SCI ACPI IRQ:                  9
  < ACPI, APM, batteries settings >
    Supported S(leep) States:      S1, S3, S4, S5
    UPS:                           No
    Thermal Zones:                 No
    Power Button:                  Yes
    Sleep Button:                  No
    Lid Button:                    No
    Display Dimming Supported:     No
    Hibernate Supported:           No
  < Wake Capabilities >
    Timer Wake State:              S4
  < Drives Power Management >
    Drives Spin Down Enabled:      Yes
    Drive Spin Range:              3 seconds(s) - 3600 seconds(s)
  < Power Schemes >
    Home/Office Desk:              This scheme is suited to most home or desktop
                                   computers that are left plugged in all the
                                   time. (Active)
    Portable/Laptop:               This scheme is designed for extended battery
                                   life for portable computers on the road.
    Presentation:                  This scheme keeps the monitor on for doing
                                   presentations.
    Always On:                     This scheme keeps the computer running so
                                   that it can be accessed from the network.
                                   Use this scheme if you do not have network
                                   wakeup hardware.
    Minimal Power Management:      This scheme keeps the computer on and
                                   optimizes it for high performance.
    Max Battery:                   This scheme is extremely aggressive for
                                   saving power.
  < APM System Status >
    AC Line Status:                On-Line
                                   tip.
<<< Displays and Display Adapters >>>
<< Video Adapter >>
<< Primary Display Driver (display) >>
  < Video Adapter >
    Model:                         NVIDIA GeForce FX 5700
    Chipset:                       GeForce FX 5700
    RAMDAC:                        Integrated RAMDAC
    Video BIOS:                    Version 4.36.20.21.00
    VGA Compatible:                No
    Total Memory:                  256MB (255MB Video) (254MB System)
    Texture Memory:                509MB
    Supports DIME Texturing:       Yes
    Version:                       3.00
    Current Data Transfer Rate:    8x
  < Video BIOS >
    Date of Manufacture:           Monday, October 20, 2003
    Version:                       4.36.20.21.AS03
  < Current Video Mode >
    Mode:                          800x600 64K HiColour (16-bit)
    Current Refresh Rate:          60Hz
    Virtual Desktop Size:          800x600
  < Video Driver >
    Model:                         nv4_mini.sys
    Version:                       6.14.10.5303
    Expected Windows Version:      4.00
    Video Acceleration:            Yes
    Screen Saver Active:           15 minutes(s)
    Low Power Saving Active:       No
    Power Off Saving Active:       No
  < Supported Video Modes >
    Mode 0:                        320x200 256 colours (8-bit) 60Hz
    Mode 1:                        320x200 256 colours (8-bit) 70Hz
    Mode 2:                        320x200 256 colours (8-bit) 72Hz
    Mode 3:                        320x200 256 colours (8-bit) 75Hz
    Mode 4:                        320x240 256 colours (8-bit) 60Hz
    Mode 5:                        320x240 256 colours (8-bit) 70Hz
    Mode 6:                        320x240 256 colours (8-bit) 72Hz
    Mode 7:                        320x240 256 colours (8-bit) 75Hz
    Mode 8:                        400x300 256 colours (8-bit) 60Hz
    Mode 9:                        400x300 256 colours (8-bit) 70Hz
    Mode 10:                       400x300 256 colours (8-bit) 72Hz
    Mode 11:                       400x300 256 colours (8-bit) 75Hz
    Mode 12:                       480x360 256 colours (8-bit) 60Hz
    Mode 13:                       480x360 256 colours (8-bit) 70Hz
    Mode 14:                       480x360 256 colours (8-bit) 72Hz
    Mode 15:                       480x360 256 colours (8-bit) 75Hz
    Mode 16:                       512x384 256 colours (8-bit) 60Hz
    Mode 17:                       512x384 256 colours (8-bit) 70Hz
    Mode 18:                       512x384 256 colours (8-bit) 72Hz
    Mode 19:                       512x384 256 colours (8-bit) 75Hz
    Mode 20:                       640x400 256 colours (8-bit) 60Hz
    Mode 21:                       640x400 256 colours (8-bit) 70Hz
    Mode 22:                       640x400 256 colours (8-bit) 72Hz
    Mode 23:                       640x400 256 colours (8-bit) 75Hz
    Mode 24:                       640x480 256 colours (8-bit) 60Hz
    Mode 25:                       640x480 256 colours (8-bit) 70Hz
    Mode 26:                       640x480 256 colours (8-bit) 72Hz
    Mode 27:                       640x480 256 colours (8-bit) 75Hz
    Mode 28:                       720x480 256 colours (8-bit) 60Hz
    Mode 29:                       720x576 256 colours (8-bit) 60Hz
    Mode 30:                       800x600 256 colours (8-bit) 60Hz
    Mode 31:                       800x600 256 colours (8-bit) 70Hz
    Mode 32:                       800x600 256 colours (8-bit) 72Hz
    Mode 33:                       800x600 256 colours (8-bit) 75Hz
    Mode 34:                       848x480 256 colours (8-bit) 60Hz
    Mode 35:                       848x480 256 colours (8-bit) 70Hz
    Mode 36:                       848x480 256 colours (8-bit) 72Hz
    Mode 37:                       848x480 256 colours (8-bit) 75Hz
    Mode 38:                       1024x768 256 colours (8-bit) 60Hz
    Mode 39:                       1024x768 256 colours (8-bit) 70Hz
    Mode 40:                       1024x768 256 colours (8-bit) 72Hz
    Mode 41:                       1024x768 256 colours (8-bit) 75Hz
    Mode 42:                       1088x612 256 colours (8-bit) 60Hz
    Mode 43:                       1088x612 256 colours (8-bit) 70Hz
    Mode 44:                       1088x612 256 colours (8-bit) 72Hz
    Mode 45:                       1088x612 256 colours (8-bit) 75Hz
    Mode 46:                       1152x864 256 colours (8-bit) 60Hz
    Mode 47:                       1152x864 256 colours (8-bit) 70Hz
    Mode 48:                       1152x864 256 colours (8-bit) 72Hz
    Mode 49:                       1152x864 256 colours (8-bit) 75Hz
    Mode 50:                       1280x720 256 colours (8-bit) 60Hz
    Mode 51:                       1280x720 256 colours (8-bit) 70Hz
    Mode 52:                       1280x720 256 colours (8-bit) 72Hz
    Mode 53:                       1280x720 256 colours (8-bit) 75Hz
    Mode 54:                       1280x768 256 colours (8-bit) 60Hz
    Mode 55:                       1280x768 256 colours (8-bit) 70Hz
    Mode 56:                       1280x768 256 colours (8-bit) 72Hz
    Mode 57:                       1280x768 256 colours (8-bit) 75Hz
    Mode 58:                       1280x960 256 colours (8-bit) 60Hz
    Mode 59:                       1280x960 256 colours (8-bit) 70Hz
    Mode 60:                       1280x960 256 colours (8-bit) 72Hz
    Mode 61:                       1280x960 256 colours (8-bit) 75Hz
    Mode 62:                       1280x1024 256 colours (8-bit) 60Hz
    Mode 63:                       1280x1024 256 colours (8-bit) 70Hz
    Mode 64:                       1280x1024 256 colours (8-bit) 72Hz
    Mode 65:                       1280x1024 256 colours (8-bit) 75Hz
    Mode 66:                       320x200 64K HiColour (16-bit) 60Hz
    Mode 67:                       320x200 64K HiColour (16-bit) 70Hz
    Mode 68:                       320x200 64K HiColour (16-bit) 72Hz
    Mode 69:                       320x200 64K HiColour (16-bit) 75Hz
    Mode 70:                       320x240 64K HiColour (16-bit) 60Hz
    Mode 71:                       320x240 64K HiColour (16-bit) 70Hz
    Mode 72:                       320x240 64K HiColour (16-bit) 72Hz
    Mode 73:                       320x240 64K HiColour (16-bit) 75Hz
    Mode 74:                       400x300 64K HiColour (16-bit) 60Hz
    Mode 75:                       400x300 64K HiColour (16-bit) 70Hz
    Mode 76:                       400x300 64K HiColour (16-bit) 72Hz
    Mode 77:                       400x300 64K HiColour (16-bit) 75Hz
    Mode 78:                       480x360 64K HiColour (16-bit) 60Hz
    Mode 79:                       480x360 64K HiColour (16-bit) 70Hz
    Mode 80:                       480x360 64K HiColour (16-bit) 72Hz
    Mode 81:                       480x360 64K HiColour (16-bit) 75Hz
    Mode 82:                       512x384 64K HiColour (16-bit) 60Hz
    Mode 83:                       512x384 64K HiColour (16-bit) 70Hz
    Mode 84:                       512x384 64K HiColour (16-bit) 72Hz
    Mode 85:                       512x384 64K HiColour (16-bit) 75Hz
    Mode 86:                       640x400 64K HiColour (16-bit) 60Hz
    Mode 87:                       640x400 64K HiColour (16-bit) 70Hz
    Mode 88:                       640x400 64K HiColour (16-bit) 72Hz
    Mode 89:                       640x400 64K HiColour (16-bit) 75Hz
    Mode 90:                       640x480 64K HiColour (16-bit) 60Hz
    Mode 91:                       640x480 64K HiColour (16-bit) 70Hz
    Mode 92:                       640x480 64K HiColour (16-bit) 72Hz
    Mode 93:                       640x480 64K HiColour (16-bit) 75Hz
    Mode 94:                       720x480 64K HiColour (16-bit) 60Hz
    Mode 95:                       720x576 64K HiColour (16-bit) 60Hz
    Mode 96:                       800x600 64K HiColour (16-bit) 60Hz
    Mode 97:                       800x600 64K HiColour (16-bit) 70Hz
    Mode 98:                       800x600 64K HiColour (16-bit) 72Hz
    Mode 99:                       800x600 64K HiColour (16-bit) 75Hz
    Mode 100:                      848x480 64K HiColour (16-bit) 60Hz
    Mode 101:                      848x480 64K HiColour (16-bit) 70Hz
    Mode 102:                      848x480 64K HiColour (16-bit) 72Hz
    Mode 103:                      848x480 64K HiColour (16-bit) 75Hz
    Mode 104:                      1024x768 64K HiColour (16-bit) 60Hz
    Mode 105:                      1024x768 64K HiColour (16-bit) 70Hz
    Mode 106:                      1024x768 64K HiColour (16-bit) 72Hz
    Mode 107:                      1024x768 64K HiColour (16-bit) 75Hz
    Mode 108:                      1088x612 64K HiColour (16-bit) 60Hz
    Mode 109:                      1088x612 64K HiColour (16-bit) 70Hz
    Mode 110:                      1088x612 64K HiColour (16-bit) 72Hz
    Mode 111:                      1088x612 64K HiColour (16-bit) 75Hz
    Mode 112:                      1152x864 64K HiColour (16-bit) 60Hz
    Mode 113:                      1152x864 64K HiColour (16-bit) 70Hz
    Mode 114:                      1152x864 64K HiColour (16-bit) 72Hz
    Mode 115:                      1152x864 64K HiColour (16-bit) 75Hz
    Mode 116:                      1280x720 64K HiColour (16-bit) 60Hz
    Mode 117:                      1280x720 64K HiColour (16-bit) 70Hz
    Mode 118:                      1280x720 64K HiColour (16-bit) 72Hz
    Mode 119:                      1280x720 64K HiColour (16-bit) 75Hz
    Mode 120:                      1280x768 64K HiColour (16-bit) 60Hz
    Mode 121:                      1280x768 64K HiColour (16-bit) 70Hz
    Mode 122:                      1280x768 64K HiColour (16-bit) 72Hz
    Mode 123:                      1280x768 64K HiColour (16-bit) 75Hz
    Mode 124:                      1280x960 64K HiColour (16-bit) 60Hz
    Mode 125:                      1280x960 64K HiColour (16-bit) 70Hz
    Mode 126:                      1280x960 64K HiColour (16-bit) 72Hz
    Mode 127:                      1280x960 64K HiColour (16-bit) 75Hz
    Mode 128:                      1280x1024 64K HiColour (16-bit) 60Hz
    Mode 129:                      1280x1024 64K HiColour (16-bit) 70Hz
    Mode 130:                      1280x1024 64K HiColour (16-bit) 72Hz
    Mode 131:                      1280x1024 64K HiColour (16-bit) 75Hz
    Mode 132:                      320x200 16M+ TrueColour (32-bit) 60Hz
    Mode 133:                      320x200 16M+ TrueColour (32-bit) 70Hz
    Mode 134:                      320x200 16M+ TrueColour (32-bit) 72Hz
    Mode 135:                      320x200 16M+ TrueColour (32-bit) 75Hz
    Mode 136:                      320x240 16M+ TrueColour (32-bit) 60Hz
    Mode 137:                      320x240 16M+ TrueColour (32-bit) 70Hz
    Mode 138:                      320x240 16M+ TrueColour (32-bit) 72Hz
    Mode 139:                      320x240 16M+ TrueColour (32-bit) 75Hz
    Mode 140:                      400x300 16M+ TrueColour (32-bit) 60Hz
    Mode 141:                      400x300 16M+ TrueColour (32-bit) 70Hz
    Mode 142:                      400x300 16M+ TrueColour (32-bit) 72Hz
    Mode 143:                      400x300 16M+ TrueColour (32-bit) 75Hz
    Mode 144:                      480x360 16M+ TrueColour (32-bit) 60Hz
    Mode 145:                      480x360 16M+ TrueColour (32-bit) 70Hz
    Mode 146:                      480x360 16M+ TrueColour (32-bit) 72Hz
    Mode 147:                      480x360 16M+ TrueColour (32-bit) 75Hz
    Mode 148:                      512x384 16M+ TrueColour (32-bit) 60Hz
    Mode 149:                      512x384 16M+ TrueColour (32-bit) 70Hz
    Mode 150:                      512x384 16M+ TrueColour (32-bit) 72Hz
    Mode 151:                      512x384 16M+ TrueColour (32-bit) 75Hz
    Mode 152:                      640x400 16M+ TrueColour (32-bit) 60Hz
    Mode 153:                      640x400 16M+ TrueColour (32-bit) 70Hz
    Mode 154:                      640x400 16M+ TrueColour (32-bit) 72Hz
    Mode 155:                      640x400 16M+ TrueColour (32-bit) 75Hz
    Mode 156:                      640x480 16M+ TrueColour (32-bit) 60Hz
    Mode 157:                      640x480 16M+ TrueColour (32-bit) 70Hz
    Mode 158:                      640x480 16M+ TrueColour (32-bit) 72Hz
    Mode 159:                      640x480 16M+ TrueColour (32-bit) 75Hz
    Mode 160:                      720x480 16M+ TrueColour (32-bit) 60Hz
    Mode 161:                      720x576 16M+ TrueColour (32-bit) 60Hz
    Mode 162:                      800x600 16M+ TrueColour (32-bit) 60Hz
    Mode 163:                      800x600 16M+ TrueColour (32-bit) 70Hz
    Mode 164:                      800x600 16M+ TrueColour (32-bit) 72Hz
    Mode 165:                      800x600 16M+ TrueColour (32-bit) 75Hz
    Mode 166:                      848x480 16M+ TrueColour (32-bit) 60Hz
    Mode 167:                      848x480 16M+ TrueColour (32-bit) 70Hz
    Mode 168:                      848x480 16M+ TrueColour (32-bit) 72Hz
    Mode 169:                      848x480 16M+ TrueColour (32-bit) 75Hz
    Mode 170:                      1024x768 16M+ TrueColour (32-bit) 60Hz
    Mode 171:                      1024x768 16M+ TrueColour (32-bit) 70Hz
    Mode 172:                      1024x768 16M+ TrueColour (32-bit) 72Hz
    Mode 173:                      1024x768 16M+ TrueColour (32-bit) 75Hz
    Mode 174:                      1088x612 16M+ TrueColour (32-bit) 60Hz
    Mode 175:                      1088x612 16M+ TrueColour (32-bit) 70Hz
    Mode 176:                      1088x612 16M+ TrueColour (32-bit) 72Hz
    Mode 177:                      1088x612 16M+ TrueColour (32-bit) 75Hz
    Mode 178:                      1152x864 16M+ TrueColour (32-bit) 60Hz
    Mode 179:                      1152x864 16M+ TrueColour (32-bit) 70Hz
    Mode 180:                      1152x864 16M+ TrueColour (32-bit) 72Hz
    Mode 181:                      1152x864 16M+ TrueColour (32-bit) 75Hz
    Mode 182:                      1280x720 16M+ TrueColour (32-bit) 60Hz
    Mode 183:                      1280x720 16M+ TrueColour (32-bit) 70Hz
    Mode 184:                      1280x720 16M+ TrueColour (32-bit) 72Hz
    Mode 185:                      1280x720 16M+ TrueColour (32-bit) 75Hz
    Mode 186:                      1280x768 16M+ TrueColour (32-bit) 60Hz
    Mode 187:                      1280x768 16M+ TrueColour (32-bit) 70Hz
    Mode 188:                      1280x768 16M+ TrueColour (32-bit) 72Hz
    Mode 189:                      1280x768 16M+ TrueColour (32-bit) 75Hz
    Mode 190:                      1280x960 16M+ TrueColour (32-bit) 60Hz
    Mode 191:                      1280x960 16M+ TrueColour (32-bit) 70Hz
    Mode 192:                      1280x960 16M+ TrueColour (32-bit) 72Hz
    Mode 193:                      1280x960 16M+ TrueColour (32-bit) 75Hz
    Mode 194:                      1280x1024 16M+ TrueColour (32-bit) 60Hz
    Mode 195:                      1280x1024 16M+ TrueColour (32-bit) 70Hz
    Mode 196:                      1280x1024 16M+ TrueColour (32-bit) 72Hz
    Mode 197:                      1280x1024 16M+ TrueColour (32-bit) 75Hz
    Mode 198:                      800x600 256 colours (8-bit) 56Hz
    Mode 199:                      800x600 64K HiColour (16-bit) 56Hz
    Mode 200:                      800x600 16M+ TrueColour (32-bit) 56Hz
    Mode 201:                      640x480 16 colours (4-bit)
    Mode 202:                      800x600 16 colours (4-bit)
  < System i2c Controller 1 >
    Model:                         nVidia GFX DDC1 i2c
    Speed:                         50kHz
  < System i2c Controller 2 >
    Model:                         nVidia GFX DDC2 i2c
    Speed:                         50kHz
  < Enhanced Video Settings >
    Animation Effects Enabled:     Yes
    Full Windows Drag Enabled:     No
    Font Smoothing Enabled:        No
    HighContrast Feature On:       No
  < Device Mode Characteristics >
    Physical Medium Width:         380 mm, 15 in
    Physical Medium Height:        300 mm, 12 in
    Recommended CRT/Panel Size:    23 in
    Horizontal/Vertical Resolution:96x96 dpi
    Colour Bits/Planes:            16 / 1 bit(s) pp
    Brushes:                       4294967295
    Pens:                          4294967295
    Colours/Shades:                4294967295
    Pixel Width/Height/Diagonal:   36 / 36 / 51
  < Driver Clipping Capabilities >
    Can Clip Output to Rectangle:  Yes
    Can Clip Output to Region:     No
  < Driver Raster Capabilities >
    Supports Banding:              No
    Supports Fonts Larger than 64K:Yes
    Can Transfer Bitmaps:          Yes
    Supports Bitmaps Larger than 6:Yes
    Supports Device Bitmaps:       No
    Supports DIBs:                 Yes
    DIBs on Device Surface:        Yes
    Flood Fills:                   Yes
    Supports Windows 2.x:          Yes
    Stretch/Compress Bitmaps:      Yes
    Stretch/Compress DIBs:         Yes
    Supports Scaling:              No
    Palette-Based Device:          No
    Saves Bitmap Locally:          No
  < Driver Curve Capabilities >
    Can Draw Circles:              Yes
    Can Draw Ellipses:             Yes
    Can Draw Pie Wedges:           Yes
    Can Draw Chord Arcs:           Yes
    Can Draw Wide Borders:         Yes
    Can Draw Styled Borders:       Yes
    Can Draw Wide, Styled Borders: Yes
    Can Draw Rounded Rectangles:   Yes
    Can Draw Interiors:            Yes
  < Driver Line Capabilities >
    Can Draw Polylines:            Yes
    Can Draw Styled Lines:         Yes
    Can Draw Wide Lines:           Yes
    Can Draw Wide, Styled Lines:   Yes
    Can Draw Markers:              Yes
    Can Draw Polymarkers:          Yes
  < Driver Polygonal Capabilities >
    Can Draw Alternate-fill Polygo:Yes
    Can Draw Winding-fill Polygons:Yes
    Can Draw Rectangles:           Yes
    Can Draw Scan Lines:           Yes
  < Driver Text Capabilities >
    Supports Stroke Clip Precision:Yes
    Supports Stroke Output Precisi:Yes
    Supports Character Output Prec:Yes
    Supports 90° Character Rotatio:No
    Supports Any Angle Character R:No
    Supports Independent X-Y Scali:No
    Supports Doubled Character for:No
    Supports Integer Multiples for:No
    Any Multiples for Exact Scalin:No
    Can Draw Double-Weighted Chara:No
    Can Italicise:                 No
    Can Underline:                 Yes
    Can Draw Strikeouts:           Yes
    Can Draw Raster Fonts:         Yes
    Can Draw Vector Fonts:         Yes
    Cannot Scroll Using BitBlt:    No
    Tip 314:                       Video BIOS is too old. Check for an update.
    Tip 319:                       A refresh rate of at least 75Hz is
                                   recommended. Increase it if possible.
    Tip 322:                       Turn off screen savers. Use the monitor power
                                   saving mode.
                                   tip.
<< Monitor >>
<< Plug and Play Monitor >>
  < Monitor/Panel >
    Device ID:                     Plug and Play Monitor
    Maximum Resolution:            1600x1200
    DPMS Energy Star Compliant:    Yes
  < PnP/DDC Monitor Data >
    Serial Number:                 01010101
    Date of Manufacture:           Sunday, August 27, 2006
    Type:                          RGB colour
    CRT/Panel Size:                19 in
    Horizontal/Vertical CRT/Panel :380 mm / 300 mm
    Gamma Factor:                  2.20
    DPMS Modes Supported:          Off
    EDID Version:                  1.03
  < Established Timings >
    Mode 0:                        720x400 70Hz NI
    Mode 1:                        720x400 88Hz NI
    Mode 2:                        640x480 60Hz NI
    Mode 3:                        640x480 67Hz NI
    Mode 4:                        640x480 72Hz NI
    Mode 5:                        640x480 75Hz NI
    Mode 6:                        800x600 60Hz NI
    Mode 7:                        800x600 72Hz NI
    Mode 8:                        800x600 75Hz NI
    Mode 9:                        832x624 75Hz NI
    Mode 10:                       1024x768 87Hz I
    Mode 11:                       1024x768 70Hz NI
    Mode 12:                       1024x768 75Hz NI
    Mode 13:                       1280x1024 75Hz NI
  < Standard Timings >
    Mode 0:                        1280x1024 60Hz
    Mode 1:                        1152x864 75Hz
<<< Communication Devices >>>
<< Lucent Venus Modem PnP >>
  < Communication Device Setup >
    Model:                         Lucent Venus Modem PnP
    Device Type:                   External
  < Driver Information >
    Port:                          COM1
    Maximum Baud Rate:             115K baud
    Data Bits:                     8-bit
    Stop Bits:                     1
    Parity:                        Disabled
    Transmission Mode:             Binary
    CTS Output Flow Control:       Yes
    DSR Output Flow Control:       No
    DSR Input Flow Control:        No
    DTR Flow Control Type:         Enabled
    RTS Flow Control Type:         Handshake
    XON/OFF Input Flow Control:    No
    XON/OFF Output Flow Control:   No
    XOFF Continues Transmission:   No
    Error Replacement Enabled:     No
    Null Stripping Enabled:        No
    Abort On Errors:               No
    Warning:                       Port in use. [5]
<<< Ports >>>
<< Communications Port (COM1) >>
    Model:                         COM1
    Type:                          Communications Port
  < Device Connected to Port >
<< ALi PCI to USB Open Host Controller >>
    Controller:                    ALi PCI to USB Open Host Controller
  < Root Hub >
    Compound Device:               No
    Hub Is Bus Powered:            No
    Power Switching:               Individual
    Over-current Protection:       None
    Number of Ports:               3
  < Root Hub: USB Port 1 >
    Status:                        Device Connected
    Device Connected to Port:      USB Human Interface Device
    OEM Device Name:               Microsoft Corp. IntelliMouse Optical
    Device Version:                3.00
    Device ID:                     VEN_045E, DEV_0039, PRT_00
    USB Version:                   1.10
    Speed:                         Low (1.5Mbps)
    Configuration Settings:        1
    Open Pipes:                    1
    Transfer Type:                 Interrupt
    Data Packet Size:              8 byte(s)
  < Root Hub: USB Port 2 >
    OEM Device Name:               Logitech, Inc. Dual Action Gamepad
    Device Version:                2.00
    Device ID:                     VEN_046D, DEV_C216, PRT_00
    USB Version:                   1.10
    Open Pipes:                    1
  < Root Hub: USB Port 3 >
    Status:                        No Device Connected
  < Root Hub >
    Compound Device:               No
    Number of Ports:               3
  < Root Hub >
    Compound Device:               No
    Number of Ports:               3
<<< Network Adapters >>>
<< Host & Network Adapters >>
  < WinSock Library >
    Version:                       2.02
    Description:                   WinSock 2.0
    Status:                        Running
  < Host >
    IP Gateway/Forwarder:          No
    DNS Service Enabled:           No
    ARP Proxy Enabled:             No
    IP TLL Value:                  128
  < Network Adapter 1 >
    Model:                         MS TCP Loopback interface
    Type:                          loopback
    Speed:                         10Mbps
    Packet MTU:                    1.5kB
    Operational:                   Yes
  < Network Adapter 16777219 >
    Model:                         ULI 5261 PCI Fast Ethernet
    Type:                          ethernet-csmacd
    Speed:                         10Mbps
    Packet MTU:                    1.5kB
    MAC Address:                   00:15:F2:C2:6A:97
    DHCP Enabled:                  Yes
    WINS Enabled:                  No
    Auto Configuration Enabled:    Yes
    Auto Configuration Engaged:    No
    Operational:                   No
  < Network Adapter 33554436 >
    Model:                         WAN (PPP/SLIP) Interface
    Type:                          ppp
    Speed:                         115kbps
    Packet MTU:                    1.5kB
    MAC Address:                   00:53:45:00:00:00
    IP Address 1:                  4.158.213.57
    IP Address 1 Subnet Mask:      255.255.255.255
    IP Gateway/Forwarder:          4.158.213.57
    DHCP Enabled:                  No
    WINS Enabled:                  No
    DNS Server 1:                  207.69.188.187
    DNS Server 2:                  207.69.188.186
    Operational:                   Yes
<< Services & Routing >>
  < IP Services (Local <-> Remote) >
    TCP localhost:epmap (svchost.e:N/A [Listening]
    TCP localhost:microsoft-ds (Sy:N/A [Listening]
    TCP localhost:1025 (mstask.exe:N/A [Listening]
    TCP dialup-4.158.213.57.Dial1.:TCP 203.121.79.139:47555 [Established]
    TCP dialup-4.158.213.57.Dial1.:TCP 211.233.65.162:504 [Established]
    TCP dialup-4.158.213.57.Dial1.:TCP 59.144.165.43:21999 [Established]
    TCP dialup-4.158.213.57.Dial1.:TCP 4.158.3.183:netbios-ssn [Time Wait]
    TCP dialup-4.158.213.57.Dial1.:TCP 4.158.3.97:epmap [Time Wait]
    TCP dialup-4.158.213.57.Dial1.:TCP 4.158.3.120:microsoft-ds [Time Wait]
    TCP dialup-4.158.213.57.Dial1.:TCP 4.158.3.56:epmap [Time Wait]
    TCP dialup-4.158.213.57.Dial1.:TCP 4.158.3.208:microsoft-ds [Time Wait]
    TCP dialup-4.158.213.57.Dial1.:TCP 4.158.216.149:microsoft-ds [Time Wait]
    TCP dialup-4.158.213.57.Dial1.:TCP 4.158.3.120:epmap [Time Wait]
    TCP dialup-4.158.213.57.Dial1.:TCP 4.158.216.149:epmap [Time Wait]
    TCP dialup-4.158.213.57.Dial1.:TCP 4.158.3.183:epmap [Time Wait]
    TCP dialup-4.158.213.57.Dial1.:TCP 4.158.3.232:microsoft-ds [Time Wait]
    TCP dialup-4.158.213.57.Dial1.:TCP 4.158.3.188:epmap [Time Wait]
    TCP dialup-4.158.213.57.Dial1.:TCP 4.158.3.232:microsoft-ds [Established]
    TCP dialup-4.158.213.57.Dial1.:TCP 4.158.216.149:microsoft-ds [Fin Wait 1]
    TCP dialup-4.158.213.57.Dial1.:TCP 4.158.0.60:epmap [Established]
    TCP nick:2551 ([System Process:TCP 4.158.3.120:epmap [Time Wait]
    TCP nick:2563 ([System Process:TCP 4.158.3.188:epmap [Time Wait]
    TCP nick:2936 ([System Process:TCP 204.13.160.129:http [Time Wait]
    TCP nick:2976 ([System Process:TCP 4.158.3.183:epmap [Time Wait]
    TCP nick:3646 ([System Process:TCP 4.158.3.48:epmap [Time Wait]
    TCP nick:3888 ([System Process:TCP 4.158.3.56:microsoft-ds [Time Wait]
    TCP nick:3958 ([System Process:TCP 4.158.3.22:epmap [Time Wait]
    TCP nick:3988 ([System Process:TCP 4.158.216.68:microsoft-ds [Time Wait]
    TCP nick:4081 ([System Process:TCP 4.158.3.22:epmap [Time Wait]
    TCP nick:4104 ([System Process:TCP 4.158.3.120:microsoft-ds [Time Wait]
    TCP nick:4134 ([System Process:TCP 4.158.216.68:epmap [Time Wait]
    TCP nick:4175 ([System Process:TCP 4.158.216.86:microsoft-ds [Time Wait]
    TCP nick:4255 ([System Process:TCP 204.13.160.129:http [Time Wait]
    TCP nick:4266 ([System Process:TCP 4.158.3.97:epmap [Time Wait]
    TCP nick:4289 ([System Process:TCP 4.158.216.77:epmap [Time Wait]
    TCP nick:4306 ([System Process:TCP 4.158.216.86:epmap [Time Wait]
    TCP nick:4319 ([System Process:TCP 4.158.3.48:epmap [Time Wait]
    TCP nick:4345 ([System Process:TCP 4.158.3.56:epmap [Time Wait]
    TCP nick:4422 ([System Process:TCP 4.158.3.97:epmap [Time Wait]
    TCP nick:4499 ([System Process:TCP 4.158.3.48:epmap [Time Wait]
    TCP nick:4536 ([System Process:TCP 4.158.3.56:epmap [Time Wait]
    TCP nick:4791 ([System Process:TCP 4.158.3.22:epmap [Time Wait]
    TCP nick:4886 ([System Process:TCP 4.158.3.120:epmap [Time Wait]
    TCP nick:4902 ([System Process:TCP 4.158.3.41:epmap [Time Wait]
    UDP localhost:microsoft-ds (Sy:N/A
    UDP localhost:1991 (SERVICES.E:N/A
    UDP nick:isakmp (LSASS.EXE):   N/A
    UDP nick:4500 (LSASS.EXE):     N/A
  < Routing Table >
    0.0.0.0 / 0.0.0.0:             hop 1 -> 4.158.213.57 LAN -> WAN (PPP/SLIP)
                                   Interface
    4.158.213.57 / 255.255.255.255:hop 1 -> 127.0.0.1 LAN -> MS TCP Loopback
                                   interface
    4.255.255.255 / 255.255.255.25:hop 1 -> 4.158.213.57 LAN -> WAN (PPP/SLIP)
                                   Interface
    127.0.0.0 / 255.0.0.0:         hop 1 -> 127.0.0.1 LAN -> MS TCP Loopback
                                   interface
    209.244.187.76 / 255.255.255.2:hop 1 -> 4.158.213.57 LAN -> WAN (PPP/SLIP)
                                   Interface
    224.0.0.0 / 224.0.0.0:         hop 1 -> 4.158.213.57 LAN -> WAN (PPP/SLIP)
                                   Interface
    255.255.255.255 / 255.255.255.:hop 1 -> 4.158.213.57 LAN -> ULI 5261 PCI
                                   Fast Ethernet
*****  End of Report  *****
i have it running on an athlon64 box with an ali/uli chipset, you should be fine.
i might also add........ pcbsd runs great on older pc's even, i had it running on a p2 300 mhz celeron 384mb ram and it was responsive and very usable.
Just wanted to add, I was just kidding....but that is an awful lot of info!
Let us know if you get it working, I was never able to get PC-BSD to work on my machine.
Sorry it is so long.
Here's how you can clean it up. Go back into your first post and click on the edit then advanced edit. Next click on the # button to get the code wrapping brackets [-code-][-/code-] (without the dashes). Put the code bracket in front of your text and the /code bracket at the end. Click on quote of this post to see how I did it.
Code:
Rights Reserved.
www.sisoftware.net) for purchase details.
URL: http://www.sisoftware.net/sandra/
E-Mail: [email protected]
Host Name: NICK
Done At: 3:28:48 PM
<<< Mainboard >>>
< System >
< System Chassis >
Type: Desktop
Can be locked: No
Boot-up State: Safe
Power State: Safe
Thermal State: Safe
< Mainboard >
MPS Version: 1.10
Model: K8U-X
< Chipset 1 >
Version: 1.04
Power Save Mode: No
< Chipset 2 >
Configuration
Version: 1.02
Version: 1.02
Channels: 1
Multiplier: 1/11x
Width: 64-bit
Power Save Mode: No
< Memory Module 1 >
Model: SUPERTALENT
Version: 1.0
Version: 7.00
CPU Voltage: 1.50V
+5V Voltage: 5.13V
Version: 3.00
Speed: 8x
Version: 2.20
Controller
Version: 1.00
Interface: OHCI
Channels: 3
Controller
Version: 1.00
Interface: OHCI
Channels: 3
Controller
Version: 1.00
Interface: OHCI
Channels: 3
Controller
Version: 2.00
Specification: 1.00
Interface: EHCI
Channels: 8
Specification: 2.00
PEC Support: No
Speed: 55kHz
Available
Support)
AC'97 Audio)
BIOS settings.
be easily upgraded.
tip.
<< System BIOS >>
Version: 0808
Is Socketed: Yes
Supports ESCD: Yes
Supports APM: Yes
Supports ACPI: Yes
< Boot Features >
tip.
<<< Processors >>>
< Processor >
Speed: 2.20GHz
Package: FC µPGA754
Multiplier: 11/1x
Generation: G8
2.4GHz 1.45-1.55V
Microcode: MU0FC03A
Type: Built-in
byte line size
byte line size
64 byte line size
< Upgradeability >
Socket/Slot: CPU 1
Version: 7.00
< Power Rating(s) >
< Sensors >
CPU Voltage: 1.52V
< Features >
SSE Technology: Yes
SS - Self Snoop: No
IA64 Technology: No
SSE3 Technology: No
SSE4 Technology: No
wrIO
wrIO
wrIO
wrIO
wrIO
wrIO
< PAT Settings >
PAT 0: WB
PAT 1: WC
PAT 2: UC-
PAT 3: UC
PAT 4: WB
PAT 5: WC
PAT 6: UC-
PAT 7: UC
BIOS settings.
tip.
<< Generic >>
<< Interface >>
< System Buses >
AGP Bus(es): 1
PCI Bus(es): 2
hypertransport >>
Revision: A / 1 (0)
Version: 1.04
Master Host: No
Unit Count: 1
Base UnitID: 0
End of Chain: No
Version: 3.00
I/O Range: No
Memory Range: Yes
Header: 00
Interface: 00
Controller
Revision: A / 1 (0)
I/O Range: Yes
Memory Range: Yes
Header: 01
Interface: 00
< Bridge Settings >
Primary Bus No.: 0
Decoding: Positive
PCI Bridge
Revision: A / 1 (0)
I/O Range: Yes
Memory Range: Yes
Header: 01
Interface: 00
< Bridge Settings >
Primary Bus No.: 0
Decoding: Positive
Support >>
I/O Range: Yes
Memory Range: Yes
Header: 00
Interface: 00
Revision: A / 1 (0)
I/O Range: No
Memory Range: No
Header: 00
Interface: 00
AC'97 Audio
Version: 2.00
Supports PME#: Yes
I/O Range: Yes
Memory Range: Yes
Header: 00
Interface: 00
I/O Range: 0000C800
Irq. No.: 18
INT Pin: A#
Controller
Version: 2.00
Supports PME#: Yes
I/O Range: Yes
Memory Range: Yes
Header: 00
Interface: 00
I/O Range: 0000C400
Irq. No.: 17
INT Pin: A#
EIDE Controller
EIDE Controller
Version: 2.00
Supports PME#: No
I/O Range: Yes
Memory Range: No
Header: 00
Interface: FA
I/O Range: 0000FF00
INT Pin: A#
I/O Range: 000001F0
Irq. No.: 14
I/O Range: 00000170
Irq. No.: 15
Controller
I/O Range: Yes
Memory Range: No
Header: 00
Interface: 8F
I/O Range: 0000CC00
I/O Range: 0000C080
I/O Range: 0000C000
I/O Range: 0000BC00
I/O Range: 0000B880
Irq. No.: 19
INT Pin: A#
bus for too long.
tip.
Controller
Revision: A / 4 (3)
I/O Range: Yes
Memory Range: Yes
Header: 00
Interface: 10
Irq. No.: 20
INT Pin: A#
Controller
Revision: A / 4 (3)
I/O Range: Yes
Memory Range: Yes
Header: 00
Interface: 10
Irq. No.: 21
INT Pin: B#
Controller
Revision: A / 4 (3)
I/O Range: Yes
Memory Range: Yes
Header: 00
Interface: 10
Irq. No.: 22
INT Pin: C#
Controller
Revision: A / 2 (1)
Version: 2.00
Supports PME#: Yes
I/O Range: No
Memory Range: Yes
Header: 00
Interface: 20
Irq. No.: 23
INT Pin: D#
Configuration >>
Configuration
Revision: A / 1 (0)
Version: 1.02
Enabled: Yes
Operational: Yes
I/O Range: No
Memory Range: No
Header: 00
Interface: 00
tip.
Opteron Address Map
Revision: A / 1 (0)
I/O Range: No
Memory Range: No
Header: 00
Interface: 00
tip.
Revision: A / 1 (0)
I/O Range: No
Memory Range: No
Header: 00
Interface: 00
tip.
Revision: A / 1 (0)
I/O Range: No
Memory Range: No
Header: 00
Interface: 00
tip.
Version: 2.00
Supports PME#: No
Version: 3.00
I/O Range: Yes
Memory Range: Yes
Header: 00
Interface: 00
Irq. No.: 16
INT Pin: A#
< ACPI BIOS >
Version: 1.00
Revision: 5.05
MP APIC: Yes
SCI ACPI IRQ: 9
UPS: No
Thermal Zones: No
Power Button: Yes
Sleep Button: No
Lid Button: No
< Power Schemes >
time. (Active)
presentations.
wakeup hardware.
saving power.
tip.
<< Video Adapter >>
< Video Adapter >
VGA Compatible: No
Version: 3.00
< Video BIOS >
< Video Driver >
Model: nv4_mini.sys
Speed: 50kHz
Speed: 50kHz
Brushes: 4294967295
Pens: 4294967295
Supports DIBs: Yes
Flood Fills: Yes
Can Italicise: No
Can Underline: Yes
saving mode.
tip.
<< Monitor >>
< Monitor/Panel >
Type: RGB colour
Gamma Factor: 2.20
EDID Version: 1.03
Port: COM1
Data Bits: 8-bit
Stop Bits: 1
Parity: Disabled
Abort On Errors: No
<<< Ports >>>
Model: COM1
< Root Hub >
Compound Device: No
Number of Ports: 3
USB Version: 1.10
Open Pipes: 1
USB Version: 1.10
Open Pipes: 1
< Root Hub >
Compound Device: No
Number of Ports: 3
< Root Hub >
Compound Device: No
Number of Ports: 3
< WinSock Library >
Version: 2.02
Status: Running
< Host >
IP TLL Value: 128
Type: loopback
Speed: 10Mbps
Packet MTU: 1.5kB
Operational: Yes
Speed: 10Mbps
Packet MTU: 1.5kB
DHCP Enabled: Yes
WINS Enabled: No
Operational: No
Type: ppp
Speed: 115kbps
Packet MTU: 1.5kB
DHCP Enabled: No
WINS Enabled: No
Operational: Yes
TCP localhost:epmap (svchost.e:N/A[Listening]
TCP localhost:microsoft-ds (Sy:N/A[Listening]
TCP localhost:1025 (mstask.exe:N/A[Listening]
< Routing Table >
Interface
interface
Interface
interface
Interface
Interface
Fast Ethernet
Now it wont take up so much room and we can still easily scroll though the entire code.
BTW I'm looking at PC-BSD too. I don't want to hassle with the FreeBSD base of 5.5 that DesktopBSD is stuck on. FreeBSD isn't too hard to install but I don't want to hassle with the learning curve right now.
Same goes with Gentoo. I just want it windows easy to install. I'll learn more about it later LOL.
I've got Windows down and don't have to work too hard at installing and tweaking it post install.
College is all the learning curve I can tolorate right now.
you'll love pcbsd. very easy to install, very easy to install extra software. the PBI system is very similar to how things work in windows.
Thanx, I'll download the PC-BSD torrent and start the preparations.
The DesktopBSD looked good except that they are slow to get the latest FreeBSD 6x base integrated.
I need a cheap PATA->SATA adaptor and an SATA cable to utilize a 40GB drive I have laying around.
I'll do the latest Live CD Gentoo install too.
My Raptor is reserved for my Windows XP installation at the moment. I may eventually get Vista to dual boot with XP but I haven't decided yet. That $400 would also buy me a real nice 12x9 PC tablet for Photoshop and other drawing apps.
i would say forget about vista, unless there is some feature that you absolutely MUST have, there is no reason to upgrade to it. Too much headache. I'd even say get rid of XP unless there is something you absolutely need it for (for me, it's games and solidworks)
I like XP a lot but Vista not so much. Windowblinds will get you that transparent window edge effect but I'm not sure how stable Windows would run with the Object Desktop Suite running in the background. Lots cheaper than Vista.
My hacked uxtheme.dll driver lets me change themes easy enough ;)
Photoshop isn't ported for Linux and I don't think the Mac version would run on BSD LOL. So it looks like I'll end up riding XP into the EOL sunset.
I'll also see how many apps I can shift over to nix.
The only issue I have with BSD is it's lack of drivers to read/write to other file systems.
I might wait until atleast version 1.5 on PC-BSD & I would get Windows XP, but Windows ME is still $100 in stores so I lnow XP is to much.
Ed, please clean up your first post. You need to wrap it in code tags like I showed you in post #8.
Why wait? If it's as easy to install as they say, you can just reinstall again when 1.5 comes out.
OTOH DesktopBSD looks like it will rock once version 1.6 gets out as that will have a FreeBSD 6.2 base instead of 5.5.
I like XP a lot but Vista not so much...............
I agree with you. The only weak areas I see in BSD/Linux are their lack of graphics/audio/video editing apps and gaming.
If Adobe Premier or iMovie type stuff was available for Linux I would be so happy. I am sure, in time, they will come.
I wish I could program.
i'm not quite sure what you guys are talking about with having to reinstall pc-bsd to change version. AFAIK, it is simple to upgrade, just as FreeBSD or the majority of Linuxes are easy to upgrade, without reinstalling. I thought they released PBI's to do the upgrade, but I might be completely wrong.
Did it for him.
FWIW.... with regard to the "detaching yourself from Windows" debate - I attended that VMware conference a couple of years back... got a free 5.x license for Linux.
I don't have an absolute killer app that I need to have, just a couple that I prefer on one platform or the other. VMware Workstation, as of their latest 5.x release, has a feature to allow running an OS that is natively installed (as in, a dual boot configuration) inside the host OS..... which, I must say, is really, really convenient. It won't suffice for gaming (you'd have to keep games in the host OS) or for any apps that directly access non-USB device hardware (ala TV Tuners, etc) but for me, it works.
The major drawback of VMware, or other emulation, was previously you were forced to run off a "virtual" disk, which was actually just a file on the host OS' filesystem. Hence, a dual boot Win/Lin machine with VMware Windows install running in Linux would have to be a completely seperate Windows install.
I have a program that needs access to my Powertap head (bicycle power computer) and it plugs in via a USB port, works great when running inside the VM. Something to consider....
Well I am just ify about the PPPoE setup & how easy that will be.
