- Apr 29, 2002
I'm looking to build a fast but cheap PC using spare parts and listed parts (see 3 posts down) from Newegg.
I'm looking over at ExcaliberPC and GameE.com for the better stepping codes for both 1700 & 2100 Tbred-Bs
I don't know how much of an overclock that MSI mobo can get without a V-core adjust and I'm not sure about the multipliers. I'm after a bang-for-the-buck Max MHz possible for a midrange O/C.
So even if those 1700s can go 1.5x spec GHz, the 1700/MSI mobo may not be able to reach the Tbred-B 2100/MSI speeds at the same mobo fsb limits. I'd be real satisfied if I can get a stable 150+MHz fsb.
I'm looking for the maximum system performance possible for ~$275.
I want to order by 4/17 before another lousy bill eats up my budget for the project. Besides it's my present to myself.
TIA,
TIA,
