I'm thinking of buying some RAM... my current OCZ RAM has failed memtest and though it's working fine and I'm not too worried about stability/accuracy/dependability (home and gaming PC), I think this is a prefect excuse to upgrade my RAM.
I'm thinking of getting an 8GB kit from a well-known brand name. Currently, Corsair, Kingston, G.Skill, and Mushkin all have offerings along my price range budget (no more than £50). However, I follow some guidelines and since I've discovered this site, I want to run them by the community to see if I got my facts straight.
This is what Gigabyte says about my motherboard's RAM support:
However, looking at RAM at various online stores, it seems like DDR3 now comes in 1333, 1600, 1866, and 2133 flavors. Am I stuck with 1333 then?
What does timings mean? Is 7-7-7-20 2x2GB better than 9-9-9-24 (2x4GB) in terms of speed? Is that speed even noticeable? Should I even bother with timings or should I just go for more GB?
If I buy 1333 RAM with different timings, will it play nice with my current RAM? Or even if it had the same timings, with 2x2GB work with a 2x4GB kit?
With 4GB of RAM, will I notice any difference in loading times/frame rates/startup time/etc with more RAM?
Thanks in advance for any help!
4 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory
Dual channel memory architecture
Support for DDR3 2200/1333/1066/800 MHz memory modules
Support for non-ECC memory modules
Support for Extreme Memory Profile (XMP) memory modules
