- Feb 7, 2011
- SoFla/Indiana
Hey guys,
My specs are all in my sig, so that's what I'll be referring to.
My motherboard was definetly a budget motherboard, I went cheap on it and I knew I shouldn't of. I might be running into some money here soon and would love to upgrade.
Currently, my MSI board has one PCI-Express slot, which holds my 460GTX. I have another, that's just lying around. I need to find a motherboard that has the capability to run AM3 socket, an SLI setup, and has more room for expansion.
My MSI board has limited overclocking abilities. It only supports up to 95W of a CPU, and my CPU is just that, 95W. I managed to get a decent overclock going (2.8 stock to 3.6 OC'd), but I have very limited options. I can't raise my voltage, and some options are just plain limited (memory timings, HT link speed, etc.)
I found this board and was wondering if it can do what I need: SLI, better overclock, better chipset
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131636
Would I be able to push my Phenom 925 further with this board? I have watercooling and my temps don't rise above 35C on load.
I know I'd have to upgrade memory but I found some good deals on DDR3.
Any input would be great, thanks!
