Good luck. The company is now called Walton Chaintech and it doesn't seem they are any longer in the motherboard business.
Just curious, mitchr84. What are you trying to accommodate with the bios upgrade?
TorqueRanger, have you tried those links to actually download the bios? I tried the first two and they take you around in circles. Looks like they are trying to get you to register for some fee-based download service which may or may not have what you want. Used to be you could actually get old drivers for free but now most all of it is fee-based. Yuk!
Precisely. I have some common sense and it wasn't a matter of turning up searches. The aforementioned links are all p2p if you want to download and even still, are those files good? A friend of mine and I tried one of those sites for something else a while ago and the files we obtained weren't even related.
Trents, I'm trying accomodate an Opteron 165 with the upgrade. Right now with no bios upgrade it's recognizing it as a "Unknown Hammer Family Processor" and will not run stable at anything past stock. When I do ctrl+alt+del at startup I only get one CPU menu. So I think it's just running single core at 1.8ghz right now. Friend of mine had my same setup -> Opteron proc, VNF4 Ultra board with OCZ ram and was cranking some serious numbers after his bios update.
check out
http://download.getabest.com/new/chaintech-vnf4-vnf4-ultra-zenith-ve-79409.html
Also check out this board reviews and problems
http://forums.anandtech.com/showthread.php?t=1494719&page=8
check out
When it started a year ago did it act that way with any other games? If so I might suspect a PSU problem with the video card sending it into "overload" because of a bad PSU.
The next thing I'd think about would be drivers, maybe video but possibly chipset, being corrupted somehow.
Plenty of other things that can cause problems that way but that's where I'd start looking ...
