Hey fellas, since you guys are gurus here I wanted to ask your advice on the following upgrade option that I have avaliable to me.
I currently have an Alienware (past expiration) with a P4 1.8Ghz CPU and a ASUS P4B266 P4 DDR motherboard with 1Gig of PC2100 Ram from crucial.com
Now this guy I know is selling a Athlon XP 2600+ 333FSB 2.09Ghz and an MSI KT4V Motherboard and I need to know if this is a descent upgrade from my current setup.
I use my computer for mostly gaming and internet stuff, so thats where the most important uses will be.
I also have a ATI brand Radeon 9800 and I know my current mobo it only 4xAGP whereas his is 8x but there is other stuff like my mobo supports a 400Mhz FSB and his is only 333.
I just need some practial advice, I know its a AMD vs Intel thing and I don't really know what the difference is betern a AMD2600 and a P41.8 because I know AMD uses that wierd 2600=2Ghz crap and it throws me off.
Also I need to know if there is certain kind of ram I need to buy for it or a better ram for gaming, etc. I used to just use 1gig PC2100 and it didnt seem different from the previous 512mhz you know, also I'm on a budget obviously so I cant buy like the best ram out there or I'd just buy a brand new system you know, heh.
Uh, also can I just swap the stuff outta my current case and plug this stuff in or do I have to reinstall windows and everything because that might be alot of trouble.
My Current Specs:
1 | DRAGON FULL-TOWER CASE SILVER
1 | ASUS P4B266 P4 DDR
1 | INTEL PENTIUM 4 1800MHZ 478 PIN
2 | 256 MB DDR PC 2100
1 | 512 MB DDR PC 2100
1 | SEAGATE BARRACUDA 40GB:9R3002-301
1 | MAXTOR 140GB HARD DRIVE PARTITIONED
1 | ATI RADEON 9800 128MB
1 | PHILIPS 4.1 DYNAMIC EDGE AUDIO
1 | 1.44MB FLOPPY DRIVE BLACK
1 | MICROSOFT XP HOME OEM
1 | KOOLMAXX COOLING SYSTEM
1 | 340 WATT POWER SUPPLY
Anyway thanks for your adivce fellas, I need it.
Laterz!
My Current Specs:
Laterz!
