Hi ther guys I have a formula iv mobo and I am wanting to hook up some more fans but ...... i have been searching high and low to find a damn fan that has the 4 pin connect that fit onto my mobo ill i can find is the tiny 3 pin or 4 pin molex powersupply great big honking thing you know what i mean. I mean the 4 pin i am trying to discribe is 4 thin straight in a row pins that stick out from my mobo with a tiny thin bit of plactic underneath them so the the connect would need to curve around that like a squearish U shape
I hope that helps but jesus can anyone find me a 80mm to 120mm fan in blue LED with that connecter so that i can change the speed straight from my windows controller I f you can find one your my personal jesus
