- Sep 4, 2006
I finally got around to building my dual core system with the Foxconn A7DA-S board. But...I can't get the integrated video to work...no monitor. The monitor is good because I'm using it now from my sig rig.
I'm wondering about the ram. It's 2x2Gig of Crucial Ballistix that is supposedly compatible with this board:
http://www.crucial.com/store/mpartspecs.aspx?mtbpoid=4D55EAD9A5CA7304
The reason that I'm "wondering", is because on the Foxconn site, this ram is not mentioned...and it lists ram that I have never heard of:http://www.foxconnsupport.com/complist.aspx?models=A7DA-S&type=MEMORY&Series=en-us0000008
And the foxconn site doesn't even list Crucial at all.
So, I wondering if maybe the ram just isn't compatible ?
Also...I get no beeps of any kind...all fans spin and both of the green led's on the board light up.
Oh yea...almost forgot...The thermaltake 500W psu that I have only has a 4 pin cpu power connector and the board has the 8 pin connector. The manual says that if the psu only has the 4 pin, to be sure and install it in the proper portion of the 8 pin connector.
Now, I don't think that just having the 4 pin and not the entire 8 pin would affect the monitor problem...but I needed to pass that along...ya never know...!
