Approximate Purchase Date: Assembly should be completed by Mid August
Budget Range: £600
System Usage from Most to Least Important: Numerical and computational analysis, engineering software (CAD, FEA, etc), Work, Gaming, expected to be running most of the time.
Are you buying a monitor: No, using my current monitors and hd tv via hdmi connection.
Do you need to buy OS: Yes, Windows 7 64 bit
Preferred Website(s) for Parts: ebuyer/dabs (UK based)
Parts Preferences: None
Overclocking: Not initially, but maybe in the future
SLI or Crossfire: Maybe
Additional Comments: It is really important that the system can manage numerical computations, efficiently. Currently for example I have an 8 GB RAM PC and there is not enough memory to run some analysis. For my analysis, I can select the number of CPU cores and amount of RAM to allocate, the more CPU cores/speed and the more RAM, the faster the analysis gets done.
I have two builds, one if based on the i5 processor and the other is based on the amd fx processor. Still not sure which way to go?
I have detailed the specs in a spreadsheet https://dl.dropbox.com/u/47274064/P [...] latest.xls
I have also listed the builds below:
AMD BUILD
Corsair Memory 600W Builder Series CX V2 ATX PSU
Antec 300 Three Hundred Case
AsRock 970 Extreme3 Motherboard
AMD Bulldozer 3.1 Ghz 8 Core
Coolermaster Hyper 212 EVO CPU Cooler
Kingston 16GB DDR3 1600MHz XMP HyperX Memory
LG DVD R
Sapphire HD 7750 1GB GDDR5 DVI HDMI DisplayPort PCI-E Graphics Card
Western Digital 500GB Caviar Blue 7200RPM 16MB SATA 6Gb/s
Crucial CT064M4SSD2 64GB M4 SSD
Total Cost: £595
INTEL BUILD
Asus P8H77-V S1155 Intel Z77 DDR3 ATX
Intel Core i5-3570K S1155 3.4GHz 6MB
LG DVD R
Total Cost: £631
I would really appreciate your
1) feedback and suggestions
2) Which one would you go for, based on my requirements
3) Any changes you would make
4) Thoughts on the cost
Thanks, I am learning lots and getting more experience before finalising my build.
Budget Range: £600
AMD BUILD
LG DVD R
Total Cost: £595
INTEL BUILD
LG DVD R
Total Cost: £631
