- Jul 13, 2011
Hi all, I just joined this forum as I have been doing some research on building my first computer and I found a lot of useful information on this site and figured this would be a good place to get some advice.
As title suggests, I want to build my first computer, it has been something that I have wanted to do for a long time. As with any project I do I usually like something challenging and unique. I am not a gamer but I use my computer for everything media to day trading and want something powerful. After reading up on liquid cooled computers I decided that I definitely want to include that in my system. Here is what my computer will include:
CPU: Intel Core i7 2600k
MOBO: Asus P8P67 Deluxe
Memory: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM
GPU: AMD 6790
Storage: 80GB SSD and 1TB WD Caviar Black
Optical Drive: Undecided
PSU: SeaSonic USA X750 Gold (I think 750W should be sufficient for this build but let me know what you guys think.
Case: Cosair 600t (white)
Ok, now that you guys have an idea of what I will be building, I would like some advice feedback on my cooling system. I want to cool the CPU and the GPU only and want to know if you guys think that 1 radiator will be enough to cool this system. These are some items I had in mind:
CPU Block: Koolance CPU 370
http://www.koolance.com/water-cooling/product_info.php?product_id=2030
GPU Block: Koolance GPU 220
http://www.koolance.com/water-cooling/product_info.php?product_id=966
Reservoir and Pump Combo: Koolance RP-1000BK
http://www.koolance.com/water-cooling/product_info.php?product_id=280
I would like to put the radiator on the top of the case and then install two exhaust fans on top of them (the case allows you to do this I believe). I was looking at this one: XSPC RS240 Dual Fan Radiator
http://www.xs-pc.com/products/radiators/rs-series/rs240-dual-fan-radiator/
I would probably run 3/8 (10mm) tubing. Let me know what you guys think, will this cooling be sufficient or will I need an additional radiator. If so I would probably have to put it in the front of the case and do some modding.
GPU: AMD 6790
