I haven't been here since my last build / unlock in 5 years. I always thought the people here were sharp.
I need a semi-high end video editing machine (720p). My last machine used 2 virtual raid 0 drives (5 physical drives total) and overclocked an AMD 9950. I currently have 6 monitors. Just want some feedback before I push the buy button.
I am upgrading from Adobe CS3 to CS6. Specifically, After Effects can now use all the memory.
Issues with last build.
1) I bought a large case, but the workstation grade nvideo card(s) still bumped against the drive stack, so I had to reposition some drives. The specs said it would fit, but with plugs, it didn't. I have a quadro CX ($1,700 ripoff, I got sucked into the hype).
2) WIth raid 0, any issue with the cpu / memory / boot means I can't get at my data.
3) Have reboot issue where I have to hold reset for several seconds to get a clean boot. I have changed memory, but problem still exists.
Goals for the new build.
1) More memory for After effects
2) SSD drives, one for boot / scatch, and one for core non-video data.
3) Not implement any raid, so if any "issue" happens, I can just pull the drives. I don't back up video clips, just finished product to an external drive (usb3.0).
4) Going from 6 monitors to 4 monitors and incorporate SLI.
5) Case the has the front usbs and buttons on the top of the case since it sits on the floor right next to me.
6) I go about 6 years between builds. No need to be on the bleeding edge.
7) I will OC.
Here is what is in the shopping cart at New Egg.
A) CPU: i5-3550 ivy bridge.
B) MEM: G.SKILL Ares Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) x 2 = 32g
C) MB: ASUS P8Z77-V PRO LGA (I like asus)
D) Vid1: PNY VCQ2000D-PB Quadro 2000D 1GB 128-bit GDDR5 PCI Express 2.0 x16 (
E) Vid2: PNY VCQUADRO-CX-PB Quadro CX 1.5GB 384-bit GDDR3 PCI Express 2.0 x16 (existing to SLI bridge)
F) SD1: OCZ Vertex 4 VTX4-25SAT3-128G 2.5" 128GB SATA
G) SD2: OCZ Vertex 4 VTX4-25SAT3-256G 2.5" 256GB SATA
H) HD: western digital reused
I) COUGAR Evolution Black SECC ATX Full Tower Computer Case USB 3.0 x 2, USB 2.0 x 2
J) PSU: Rosewill Stallion Series RD700 700W ATX12V V2.3 SLI Ready CrossFire Ready Power Supply
K) DVD: reuse
Specific questions
A) i5-3550 ivy or i5-2500 sandy?
Anything I am missing??
7) I will OC.
K) DVD: reuse
Specific questions
