Primarily for gamers? QUe? The X79 performs the same as Z77 SB to SB-E. Its primarily for whatever you want it to be for. Perhaps its BOUGHT more for gaming, but certainly not a gamers paradise (actually, what do you even mean by that? LOL!)?
Ive been reading his 1st post and needs as well... In fact I touched on those points in nearly every post.. the problems he had really doesnt come in to play here (cases - I dont touch cases, Raid0 - doesnt seem he's doing that because of the problems?, and reboot issue - its a new PC so that is a moot point.
Anyway, hopefully now that things have been corrected he can see the actual facts about how hardware performs and make his choice accordingly. Honestly, he cant go wrong with either platform, just one costs more money for little reason.
EDIT: And I think you meant runs cooler it lasts longer.
EDIT2: @ Divine -
3. 3820 is not an upgrade from 3770k or 2600k
4. Sammy are solid SSD's = good choice
6. PSU is fine. That system wont break 400W highly overclocked and fully loaded.
You think since he 'redoes' everything paying more now for a questionable upgrade path is worth it? You'll never be my accountant!!!Divine said:My experience both at work and at home is the concept of upgrades sound great, but in reality, everything gets redone.
Did you read what I said? They dont run warmer until you starting really pounding on the CPU. And even then again, it can handle the heat if he chooses to push 4.5Ghz.EDIT: It might appear like bantor, but common sense tells me when something runs hotter, it will last less longer.
EDIT2: @ Divine -
1. Lowering memory speed = good choiceLowered mem to 1600.
Changed motherboard, look at a bunch.
Upgraded to i7-3820
Changed ssd to samsung.
I think I found a good case, but the jury is always out until the build. This case has fans.
Power supply is a bit underrated at 630, but my experience is the only time I push the system is when I am doing a Motion Graphic gen. I am not a gamer.
