- Feb 6, 2011
Hey guys, building a new comp for the first time. Did a decent amount of research but I'm looking for a second opinion from some of you more knowledgeable OC peeps... here are the specs:
Case: COOLER MASTER HAF 912
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119233
Mobo: MSI 870A-G55 AM3 AMD 770 SATA
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813130558
Video Card: SAPPHIRE Radeon HD 6950 2GB
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814102914
Processor: AMD Phenom II X6 1100T Thuban 3.3GHz, 3.7GHz Turbo
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819103913
Ram: G.SKILL Ripjaws Series 4GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231313
HD: Crucial SSD 64gb (Running Windows 7 64bit from)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820148357
PSU: Sunbeam PSU-H680-REV-US 680W ATX
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817709027
CD/DVD Drive: LG CD/DVD Burner w/LightScribe Support
http://www.newegg.ca/Product/Product.aspx?Item=N82E16827136221
So I was wondering what you guys think? This is my first time building a computer from scratch, I had to cut a few corners to stay on budget... things like "mobo" "cd/dvd drive" "SSD space" "PSU" no heatsink (using the stock one that comes with processor until I can afford an upgrade) "4Gb" (but will upgrade to full 16gb in time)
So just wondering what you guys think? comments? suggestions? I was mostly wondering about the mobo, is this suitable? it's only 99 bucks from newegg and it seems to be pretty decent, room for upgrading etc, but looking for some more knowledgeable opinions on this build. Much appreciated.
