Hi guys, was thinking about piecing something new together. Over the weekend I ended up buying a Define Mini C TG. I thought it was the atx model. When the guy showed up and I had a look, it looked a little small. Turns out I was right, figured it out when my mobo wouldn't fit lol.
I really like that case. Its nicer than my R4 heh.
So I put together a little list of things.. Maybe one of you gents could look it over? I am running 3rd gen i7 hardware presently, I would imagine that little box should properly whoop this thing.
CPU: 9600k
https://www.newegg.ca/Product/Product.aspx?Item=N82E16819117959
Mobo: Asus TUF Z390M
https://www.newegg.ca/Product/Product.aspx?Item=N82E16813119161&ignorebbr=1
Ram: G.Skill TridentZ
https://www.newegg.ca/Product/Product.aspx?Item=N82E16820232201&ignorebbr=1
Or, I could just buy a Maximus V Gene from ebay
https://www.ebay.ca/sch/i.html?_nkw=maximus v gene&ssPageName=GSTL
Thoughts? I can go either way, not too sure I trust ebay yet, I haven't bought anything from there.
CPU: 9600k
