- May 17, 2013
Hello ,
REQ :
Hard core gaming pc.
High OC(going to be a bit of a problem here ).
Mid-high budget. SSD - good but not too good for gaming.
Budget : below 1400 $ (No need in GPU , I am going to use my older one , it's brand new GTX 570 OC VER - only 2 months old)
No need in windows include. not living in the US.
Main use : Flight simulator X -which means i need high CPU Clock then a good gpu...
Intel Core i7 Haswell 4770K 3.5Ghz 8MB L3 Cache s1150 - Box
NH-D14 - Getting better results then the h100i in must've 4770K Benches ??
Gigabyte GA-Z87X-UD3H LGA1150, Intel Z87, DDR3 1600, 3xPCI-E,VGA, DVI, HDMI, DP
Corsair 2x4GB DDR3 1600Mhz Vengeance Blue Dual Channel CL9-9-9-24 or Value version (cheaper)?
Nvidia GTX570 OC
Seagate 1TB Barracuda 7200RPM 64MB Sata III ST1000DM003
Samsung 840 Series 2.5'' 250GB SSD SATA III(do i realiy need pro series for gaming ?)
LG DVD±RW GH24NS x24 Black SATA OEM
SeaSonic SSP-650RT 650W Gold Active PFC 12CM Fan PSU - SS-650RT OEM or SeaSonic G-650 650W Gold Modular G-Series Active PFC 12CM Fan PSU or Corsair GS 700W V2 Series Active PFC 14cm Fan PSU or Corsair TX 650W V2 Active PFC 14cm Fan
Corsair 500R Carbide Black Mid-Tower Case (No PSU) or Antec Eleven Hundred The Advanced Gaming Authority Case ?
What do you say ?
TNX.
REQ :
Nvidia GTX570 OC
What do you say ?
TNX.
