- Dec 14, 2010
So, a few days ago I started looking into making a parts list for a new build.
I typically use my main PC for email, internet browsing, gaming, listening to music, watching youtube videos, backing up hard drives, performing scans for viruses and malware on drives.
This build won't happen right away, it might not happen for several months actually, but I wanted to at least get a start on getting an idea of what I would want in my next computer.
Problem is I'm unsure on some things, and could use advice or suggestions on some areas.
I had planned on building a Sandy Bridge or Ivy Bridge PC on LGA1155/Z77, but I never seemed to have enough spare cash on hand to complete the build, and then Z87 and Z97 were released which messed up my plans a bit and I'm having to restart the planning process again since it wouldn't make much sense to build a Sandy Bridge PC when Haswell is out and SB is now two generations back.
I'm not 100% sure on the motherboard. I usually look at Asus, EVGA, and Gigabyte. I used to like MSI (had one in the build I used from 2006-2011), but I keep hearing their quality is pretty much junk these days. So far I'd looked at the Asus Sabertooth Mark 1, Asus Maximus VII Formula, ASRock Z97 OC Formula, and ASRock Z97 Extreme 6. Not sure which Gigabyte ones are considered good. Are there any good one's I'm missing?
I thought I was sure on the case. I was planning to go with a Cooler Master HAF X, since I bought one like a year ago in preparation for my next build, but now I'm not so sure. I was thinking of using my recently acquired CM Nepton 280L for cooling, but now I've realized that the HAF X can't fit a 280mm radiator, so that's a serious problem if I go in that direction. Many new cases have come on the market since I started my search for a HAF X, and some of them are no doubt better in some ways. I'm not sure it's worth it to buy a different case just to have the ability to fit a 280mm radiator though, or if there are features in newer cases that would make them more worth-while to buy.
On the SSD, I'm not sure if 256GB will be enough or not. With my current PC I have a 320GB hdd for my boot drive, and I'm using up nearly 200GB of that after I transferred all the files and folders for things I don't use every day to my secondary drive for storage. Most storage on the main drive is being used by games actually, the installs for BF4 and Titanfall are huge.
On the memory, I'm thinking 16GB will be the minimum, because I have 8GB now and it really doesn't seem like enough. I often hit 80% or greater memory usage when gaming, and when the usage goes up that high I often see system lag and/or game lag when I'm gaming. Plus I'm running temperature and voltage monitoring software in the background (on secondary monitor, so that I can glance over and check it while playing) that takes up a little bit of the system resources. It's not unusual to see 35-50% memory utilization when I'm just on my internet browser surfing or doing research on things. I'm not 100% sure on what I should go with as far as the memory frequency, I know 1333MHz will probably be too slow, and I'm assuming the minimum would be 1600MHz or 1866 MHz but I'm not sure what speed I should be at for the kinds of things I use my PC for.
http://pcpartpicker.com/p/cZ8sWZ
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor $339.99 Newegg (Overridden) (Free Intel STEAMPUNK Giveaway voucher code w/ purchase, limited offer)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler $0.00 (Purchased)
Motherboard: Asus SABERTOOTH Z97 MARK 1 ATX LGA1150 Motherboard $239.98 Newegg
Memory: Corsair Dominator Platinum 16GB (2 x 8GB) DDR3-1866 Memory $229.99 Newegg (Overridden)
Storage: Samsung 850 Pro Series 256GB 2.5" Solid State Drive $181.98 Newegg (Overridden)
Video Card: EVGA 02G-P4-3660-KR GeForce GTX 660 Ti 2GB 192-Bit (Purchased)
Case: Cooler Master HAF X ATX Full Tower Case $0.00 (Purchased)
Power Supply: Corsair Professional CMPSU-HX750 750W 80+ Silver Certified Semi-Modular ATX Power Supply $0.00 (Purchased)
