- Mar 21, 2004
So i have been putting parts together for about a week now. And i want to get this finished so I can get it built already. I am moving for a 2.8/478 CPU, Chaintech MB, 2gb of ram and a 6800BFG. One of the reasons to upgrade some games I just cant play like i used to when this system was built of course. Bioshock setting has to be turned down etc. Also i have been doing more video encoding and burning, and it really lags the system down. Video editing is not top on the list but it is a reason to upgrade. Also my Chaintech MB is having some problems, not even going to go into that.
So i have picked out a few different parts let me know what you think or if i should move to something different. price range is 1500 i would like to stay in this area with a case, and cooling
MotherBoard: undecided in this area
1. ASUS P5Q-E LGA 775 Intel P45 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131296
I have read a lot of good reviews on the ASUS boards and people suggest the asus board all the time. I picked this one over the deluxe for the extra pci x16 slot.
2. EVGA 132-CK-NF78-A1 LGA 775 NVIDIA nForce 780i SLI ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188024
This is another board i like and reviews are pretty good. Main reason for picking this one is the same as the other. Just a different brand.
CPU: Undecided in this area
1. Intel Core 2 Duo E8500 Wolfdale 3.16GHz LGA 775 65W Dual-Core Processor Model BX80570E8500
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115036
Heard good things about the Duo and i think this will handle what i am doing fine.
2. Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor Model BX80562Q6600
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
Same price as the DUO just don't know if it will help that much. in the long run.
Memory: Witch one is better
1. CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model TWIN2X4096-8500C5DF
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145197
2. GeIL Evo One 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model GE24GB1066C5DC
http://www.newegg.com/Product/Product.aspx?Item=N82E16820144213
Both are good from what i have been told. Reviews look ok on both.
PSU:
PC Power & Cooling S75QB 750W ATX12V / EPS12V SLI NVIDIA SLI Certified (Dual 8800 GTX and below) CrossFire Ready 80 PLUS Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703009
I am also looking at the 850W but this should be more then enough power for what i need.
Graphix:
BFG Tech BFGE88512GTSE GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814143119
Card should be fine i think. I looked at the 260 and the 280 i don't see that much of an increase for the price i am going to pay for one of those cards. I plan on only running one Card.
HD: x2 Western Digital Caviar SE16 WD2500AAKS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136161
I don't store any info on my main comp it is all on the server so these should be fine. Also heard good things about the SE16's
As for the Case i am still not sure thinking of the Thermaltake Armor+MX VH8000BWS Black Aluminum / Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133062
Might go with a different case not to sure in this area yet.
Cooling:
Undecided on either a Thermalright Ultra-120 Extreme or water cooling from Danger Den. not sure witch way i am going to go yet. water cooling is priced at about 240 for what i want. I can give more detail on the parts if you want.
Sound Card:
Think i am just going to stay with the on board i use optical out to a receiver so not really a need for another part.
OS:
Probably going to go with XP 64 Still alot of stuff i use on XP, emulators and stuff that do not work on Vista yet. I will upgrade to Vista down the road just not yet.
I just need a little help guys. Also there is the DDR3 going on. I don't even know if it is wise to spend that much right now. As the computer i am on now i would like to get 4 years out of it with some upgrade as i go along. Also looking at the Gateway 24" monitor upgrade from the gateway 22" The monitor is not the money for the computer. I actually thought about just buying a prebuilt then Archer36 Preety much called me a wimp. So this is where i am at peps give me a hand.
PSU:
Graphix:
Cooling:
Sound Card:
OS:
