- May 4, 2011
Hey guys, The issue I have is this:
I am currently using a 530 watt PSU(Raidmax) I know it is crap, and I will replace it once i go to build my new system.
The question is as follows: Is it strong enough to run a Geforce GTX 560 Ti?
I know the requirements for the card is 30 amps, and it has 35 amps on the v12, But considering how cheap it is, I don't want to take any chances.
Another note, Is it powerful enough for the next step up, the 570, and is it worth it? I couldn't get any ampere information on the 570, only wattage use. I figure if the 570 is only $30 more than the 560, might be worth going with that.
I am asking this because I'm going to buy my video card before the rest of my new system to lower the costs of building the entire rig.
Eventually, I'll be using a Kingwin Mach 1 1000 watt psu:
Would I be able to SLI 2 560's, and use my current 260 as dedicated Physx?(with the 1000 watt of course)
If so, Might be worth getting a triple slot pcie board.
Also, on a side note, Has anyone gotten the EVGA Geforce GTX 560 Ti DS series yet? any acoustic info? Thermal info compared to single fan?
*edit: Current CPU is a Core 2 duo e7200(going to temporarily replace with a Core 2 Quad q8800 from a friends old pc)
merged posts
-mbentley
Hey guys, Let my give you a run down of what I am currently using.
Current System:
Intel Core 2 Duo e7200 @2.93 GHZ
ASUS Pk5/se-epu Mobo LGA 775
WD Caviar Blue 250 GB
EVGA Geforce GTX 260 875 MB
Raidmax 530 Watt PSU
Raidmax Smilodon Case
System of interest:
Intel I5 2500k
Tuniq CR-T120-EX-SV 120mm Magnetic Fluid Dynamic Bearing Tower cooler
ASUS Sabertooth P67 Or GIGABYTE GA-P67A-UD5-B3 (If what below works*)
WD Caviar Black 1 TB 64 bit cache
OCZ Vertex 2 60 GB OS boot drive
EVGA Geforce GTX 560 Ti SD x2(eventually) +*Geforce GTX 260 Physx
*=Will this work with SLI enabled? Going to use as physx for sure until SLI card comes in. use sli and physx dedicated card? possible??
Cooler Master HAF X case
Either Kingwin Mach 1 1000 watt PSU, or a 850 watt gold, dont really know yet.
Couple questions on the build.
1: Can I use Physx enabled card with SLI cards enabled?
2: If above question is yes, then will I need 1000 watts for the three?
3: What is a Good, reliable board that has 3/4 PCIE slots that isn't overly expensive?(budget of $1500 +/- 75)
4: Acoustics...How loud is the new EVGA GTX 560 ti DS?\
5: Would I be able to "get away" with a 560 ti with the 530 watt early?
Luckily I don't have to buy a monitor/keyboard/mouse, so cuts my costs a bit.
Thoughts?
merged posts
-mbentley
Current System:
System of interest:
Intel I5 2500k
Thoughts?
