When I turn it on using the power button, it powers on for a second, during which time the fans just start to spin. The power supply fan gets going, the heatsink fan doesn't even get to go around a few times, it just moves a bit or goes around once or twice. So then it shuts down for a few seconds, only to start up again. I left it for about 30 seconds and it kept repeating the on-off process. If I try to push the power button to turn it off, it doesn't respond. When I flip the switch on the back of the PSU, it goes through one more round of powering on and off and then turns off.
I've tried reseating the heat sink and processor, but I didn't remove and reapply the thermal compound (it was late and I just wanted to get it to turn on for a few seconds). I've got a blue orb II anyway.
I do not have a monitor connected because my onboard video is VGA and my LCD's use DVI and I don't have an adapter, my new video card is on its way.
Do you guys think it could be because no monitor is connected?
I'm going to try inserting each stick of ram individually.
I'm going to try using a screwdriver on the power switch to see if that is it.
I'm going to try powering on the motherboard while it's removed from the case to see if there is a short.
I have the lanbox lite case, Gigabyte micro atx GA-G33M-DS2R, Crucial ballistix, Q6600 G0, Orb II heatsink, Corsair HS620W power supply.
The motherboard has the contacts around the screw holes and I have it just screwed in. There is one hole on the motherboard that has ground contacts that the case has a metal pin that goes through it, so I don't have that hole screwed down. I don't have any other standoffs or anything. The case has black foam between the metal and the motherboard. I'm wondering if the board is shorting on the case. They didn't give me any standoffs with the case, just screws. I'm assuming I don't need them.
I've built 2 other computers, but that was like 4 years ago.
My old build is so old I can't test most of my parts.
I disconnected my hard drive and optical drive and still no change.
If anyone can give me some stuff to try, I'd appreciate it.
