Hey everyone
I'm going to be building a new gaming pc , just have a couple of questions.
The current spec :
Intel Core 2 Duo E6300 S775, 1.86Ghz, 1066Mhz FSB, Conroe Core, 2M Cache OEM (w/o Heat Sink Fan)
Gigabyte GA 965P-DS3 iP965, S775, PCI-E (x16), DDR2 533 / 667 / 800, SATA II, SATA RAID, ATX
Antec Super LANBOY Aluminum Super Mini Tower Case - No PSU
580W HiperPower Type-R Modular Blue PSU Quiet Dbl Fan aPFC ATX2.2 20/24 Pin (RoHS)
Arctic Cooling Freezer 7 Pro - P4 up to 4.4GHz - S775 Dual Core / Core2Duo Ready
Corsair 1Gb (2X512Mb) Corsair TwinX XMS2, DDR2 PC6400 (800), 240 Pin, Non-ECC Unbuffered, CAS 5-5-5-15
160Gb Maxtor 6G160EO DiamondMax Plus 17, SATA300, 7200 rpm, 8MB Cache, NCQ, 9.0 ms
256MB Leadtek 7900GS PCI-E (x16), Mem 1320 MHz, GPU 450 MHz, 20 Pipes, 2x Dual Link DVI-I/HDTV
First off, my mate said that if i'm going to overclock it's best to get good ram i.e. PC6400 so I decided to go for 1Gig of PC6400 rather than 2 gig of something else. As the super lanboy is a small case will all this hardware fit well? I'm not sure what cpu cooler to get (it really depends on what fits in the case) at the moment i'm looking at the Arctic Cooling Freezer 7 Pro, has anyone use this? How well does it perform and how loud is it? Last question Is it worth paying the extra and getting the e6400?
Thanks in advance, matt
Sorry if i've posted in the wrong place I wasn't sure where to post
The current spec :
