its been about 4 years since i've built a PC. haven't even so much as cracked one open for about 2.... life's just been too hectic to bother
i've done a lot of research on this but i'm, of coarse, finding mixed information and having a hard time deciphering the contrived marketing reviews from the real ones....
so, i'm realllly thinking i need the advice of people that have kept up with the market
first, thing is i have a 60" Samsung 1080i DLP in my living room
one day, just for the fun of it, i hooked up my current PC to see how it worked...
it was freggin awesome! i was able to push the res to 1900x1300 with stunning clarity - actually got too small from my couch!! loads of extra "real estate" when i was expecting simply super-sized icons.... but i only have an old ATI Radeon 9200SE so when i try to run games i either have to put up with low resolutions, which is really bad on such a large screen, or horrible FPS and lag...
so, my goal here is to create a comp, for a decent price, that will rock the house, with say bioshock, on my big-screen. i also intend on getting blu-ray on it for movies once the prices are a bit lower... so really i'm looking to build a gaming/media center for a 60" HDTV
nothing else though - no heavy calc progs like autocad or SDS3 etc. no sharing on P2P stuff or playing with kiddy scripts... - just games and media
what i have put together thus far is:
-MSI P6N Diamond OR Asus Striker Extreme
-Leadtek WinFast PX8800 GTS TDH GeForce 8800GTS 640MB 320-bit GDDR3 PCI Express x16 HDCP Ready SLI
-Intel Core 2 Duo E6750 Conroe
-2x Kingston HyperX 1GB PC2 6400 OR 1x Patriot Extreme Performance 2GB
-2x SAMSUNG SpinPoint T Series HD403LJ 400GB 7200 RPM 16MB Cache SATA 3.0Gb/s
-Rosewill RX850-S-B 850W SLI Ready,APFC,ATX12V v2.2/EPS12V v2.91 Power Supply
-an LCS that i am still working the details out on
this all comes out to about $1600 without the "pretty" - kinda steep maybe, but i put this same config together on dell.com and they said $5,200!! And that would potentially be with some no-name parts...
I **might** be willing to push this upwards of 2k, so if you have any advice in that regards - let me know but remember, the higher the price the more i'll have to bicker with the wife over this... with that said i have the intention of, in the near future, getting another 8800GTS and running SLI and pushing my system up to 4GB memory - just so you know
my questions now are...
1. MSI vs ASUS - i used to be big ASUS fan, but i'm hearing and reading that they are now having stability issues, like M$ took them over... - on the other hand from a comparison at tom's hardware the ASUS could OC far far better while the MSI ran games better under normal loading. however this was based on a pre-release of the MSI bios... so, now that these boards have matured a bit since then which is really better? i also should consider that the MSI board is $50 cheaper.. i've also read in some places that the soundblaster xFi on the MSI is actually a crap card... but yet it still seems to get hype - which is it??
2. Will i be selling my system short with the CPU i've selected? it seems from what i've read that this chip is about minimum for the 8800GTS-SLI to see its potential.
3. "Leadtek" ?? i'de never heard of these guys before, but this card has great reviews on newegg and elsewhere - is it a gamble? or should i push for EVGA, or? Also, would it be worth it to wait for the price to drop on the 8800GTX or even the Ultra given my application here? from what i've found i'm thinking the GTS in SLI will do great, but then again i'm kind of pushing its application here...
4. I would prefer the 2GB patriot memory - if, for no other reason, to eventually push it up to 8GB - but no decent board seems to support them and they seem to support no decent boards!... yet i know i've seen a few places that people are using these on ASUS boards with no problems (just have to adjust the BIOS of coarse) are they full of it? and if not what about MSI? is there another memory that anyone would recommend?
5. is 850W enough? i used a calculator for this set-up and came up with 750, but i'm not certain of what, if any, potential perks there are to having more... also, as with Leadtek - i have no experience with Rosewill - do they bloat their wattage ratings? tend to burn? i'm really not finding much in the way of reviews for this item; just, from what i can tell, it seems like a great PSU... anyone disagree?
6. does 64-bit Vista have supported drivers for everything i'm using? i'm not sure what all must be 64-bit compatible and searching for this information is turning up a general "dont go 64" attitude and not much more real information, and at that these postings seem dated at best - is the attitude still here? even more than that should i even go Vista? i've had someone tell me that vista is too unstable - but.. for what i'm wanting to use it for, it would be a good idea... not sure what this is founded in, i just know i dont want to end up needing to buy another OS for this comp in the near future
7. lastly, the obvious question - does anyone see any conflicts in this set-up? i basically started with the GPU and built around it - so there really shouldn't be, but...?
thanks in advance for the help guys
and sorry about the length of this post - got out of hand way too quickly on me...
