Hey guys,
Okay first - the specs:
DFI LanParty UT nF4 ULTRA-D Motherboard
AMD 64:3200+ CPU
2 x 512 Corsair XMS series PC3200 DDR
Radeon X800XL Graphics Card (PCI Express)
WD 80Gig HD (Ultra ATA)
WD 74 Gig Raptor (SATA)
Seagate 160G Barracuda (Ultra ATA)
NEC ND-3520A DVD+/- RW Drive
LiteOn DVD Drive
Tsunami case
500w FSP Fortron Blue Storm PSU
SB Audigy 2 ZS
Here are the problems:
1) My Seagate drive was not being recognized on My Computer but it WAS recognized in device manager. When I went to disk management it said "Disk 1: Dynamic. "unreadable" I *really* dont want to lose the files I have on it so this is all I know to do:
- I'm pulling the files out using "Recover My Files" app. Then I guess ill use the option to convert it to a "basic disk" once the files are safe. Right? Is there an easier way to get it to be readable and bring my files back?
2) It's being much slower than I thought a 64 bit system would run. My 2800 Barton ran faster, or seemed to, for some reason. Are there any changes I should check in bios that could cause this? It has a 200 FSB I believe.
3) The computer is freezing when I run the driver CD for this motherboard. I think its just the CD though, so ill try and pull them online.
4) When my computer restarts my Dell 20.1 widescreen monitor (FPW model, or something) reverts to a different view mode that splits the screen in half (like a picture in picture) and I have to adjust it every time. Makes no sense.
5) When I first got it built and started it up everythin was going fine. It did the "rev up" sound and then suddenly died away. The fan on the heatsink stopped spinning, but the computer continued to load into the motherboard logo.
- somehow I fixed this, dont know how. I noticed when I removed the 12v plug-in from the motherboard (the small plugin on the PSU) the heatsink wouldnt shut off after reboot but the monitor wouldnt turn on (it controls the vid card, I guess?). This stil worried me though.
If you can answer ANY of these id greatly aprpreciate it. I spent a good chunk of my savings on this build and I want it to run as best as possible.
Thanks,
Bolt
AMD 64:3200+ CPU
LiteOn DVD Drive
Tsunami case
SB Audigy 2 ZS
Thanks,
Bolt
