- Aug 29, 2010
- NC
I just ordered parts from newegg to replace my old PC, which died , It was sooner than I expected (I had been planning a ~$700 build around a bulldozer, but I got a $600 build around a locked Sandy Bridge chip.
My parts:
Windows 7 Home Premium
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
i5-2400 3.1 Ghz Sandy Bridge
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115074
AS Rock H61M-VS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157241
Muskhkin 4GB DDR-1333
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146748
500 GB Seagate SATA 2 Hard drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148395
LG DVD burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136216
Corsair CX430W
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161348
HIS HD 6850 1GB
Roswill R-102 Micro ATX Minitower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147111
Blue 120MM Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835200049
generic 80mm fan to replace shroud, if necessary (not purchased, just lying around, I have at least 4 that can be cannibalized from hulks of old builds)
A generic usb keyboard & mouse I already have will be used with this computer
My existing monitor is a 21.5" Acer 1680x1050 model, and I'll use that for now, Might occasionally hook it up to the 42" 1080p TV.
I know the 2400 is limited in overclocking, but here's my questions:
Can I still up the +4 Bins on an H61 barebones mobo?
the Extreme PSU calculator, with 100% TDP, 90% System Load and 20% Capacitor aging suggests 380W for a 3.5 GHz Overclock, and 393W for 3.6 overclock, so my 430W PSU seems like it should be good to handle this, assuming its a solid and stable OC, for at least 2 years of regular use.
Many will wonder if the 6850 will fit in this small case. the 6850 is 9.1 inches long, which is shorter than the 9.6" motherboard. It should fit, but might block one of the internal hard drive slots. Not serious, as I only plan to use at most 2 of the 4 spaces anyway (eventually add an SSD)
the RAM and Video card I'll be mostly leaving alone, though can anyone suggest timing changes for that mushkin ram?
Anyone have any other suggestions? Parts have already shipped
My parts:
AS Rock H61M-VS
LG DVD burner
Corsair CX430W
HIS HD 6850 1GB
Blue 120MM Fan
