Hi all, new here FX6300 with a coolermaster 12 evo, ASUS M5A78L-MUSB3,16gb ram, old GeForce GT520, Windows7 64bit.
OK built this for HD edit/ encoding' not the best i know' but was on a budget.
When encoding with dvdfab or such like all six cores are used but not 100% go up and down between 70 and 35% is this normal? I want it to be fast and leave it to do its thing not multi task. I went in bios turned off turbo power/cool and quiet and overclocked it to 4.1 just with the multiplier!! not made much difference. The file it's encoding from is on another hdd via usb2 could this be the problem?
Thanks
Thanks
